When I push power button, it blinks a few times and stays red
SOURCE: The tv wont turn on
hello 2 blinks on this tv means you have this issue below
PT-44LCX65
2 blinks 5 secs you have your lamp cover open
check for this
hope this helps
SOURCE: Set will not power on.. Blinks red LED 8 times
It's a power supply related problem.
The flashing 8 times is a trouble code. A Service Manual for your TV model will have the info on the codes. It could be a bad capacitor or a transformer on the power supply board.If you have some electronic experience, you can find a Service Manual for your TV over the internet. Cost about under $20.
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
SOURCE: Wii balance board power light does not stay on
You need to Sync it first.Open the SD Card slot cover on the front of the Wii console, just below the disc drive, then push the red button there, then open the batteries cover on your Wii Fit and push the red button there.
SOURCE: My Panasonic TH-42PZ700U 42in. TV doesn't turn on
Power supply board have dead capacitors.U know how to solders?Buy these capacitors to replaced them to have power back.Or u can buy a whole power supply board for the replacement at these websites Shopjimmy.com,Ebay.com for refurbish power suppply board.
