Top key row, 4th button from right, is wifi on light,
answering for this LED lamp is dead, when pressed.
means driver dead.
Presario 2000 PC old, no OS stated so answers will be wrong, lacking that KEY FACT unstated by you.
6 years old PC true name below.
HP 2000 Notebook PC Compaq Presario CQ58 Notebook PC
came new with Windows 8.
if you upgraded to w10 things break sure. did you?
here is the problem with you not stating the service tag full data and that Pn 123abc.ABA#
the ABA tells the HP expert what chip is there.
modules called wifi mini-pci.
Item Component Spare part number (the offical list of chip OPTION only for YOUR PC sold new)
(16)
WLAN module:
Atheros AR9485 802.11b/g/n 1x1 WiFi Adapter
675794-001
Atheros 9485GN 802.11b/g/n 1x1 WiFi and 3012 Bluetooth 4.0 Combo Adapter
655795-001
Broadcom 4313GN 802.11b/g/n 1x1 WiFi and 20702 Bluetooth 4.0 Combo Adapter
657325-001
Ralink WLAN Ralink Ripple3 RT5390F_802.11 b/g/n 1x1 PCIe HMC
670691-001
Atheros AR9565 802.11bgn 1x1 WiFi + BT4.0 combo Adapter
690019-001
Ralink RT3290LE 802.11bgn 1x1 Wi-Fi and Bluetooth 4.0 Combo Adapter
690020-001
Ralink RT5390R 802.11bgn 1x1 Wi-Fi Adapter
691415-001
so what we do in a shop
is run our scanner PCI-z and others.
and find what chip is there.
or pop the wifi hatch and look first.
then load the correct driver what is SEEN THERE.
that is it, or call HP and get there help.
https://h30434.www3.hp.com/
condensed.
1: the card must be there, inside, wifi
2: there are 6 cards used (opted) day 1 new.
3: then go to HP and get a driver that matches.
hint ask them not us we are not HP.com ok?
4: then google how to set up wifi. if in your home, say in my home , you never did.say.
5: the airplane mode button must work or the driver IS WRONG or card missing.
go to HP and get your drivers.
then RTM read the manual on same page. RTM.
then press wifi key, make it glow.
then using your wifi credentials logon a home.
if not at home say so..
SOURCE: need wifi driver for presario c754tu with xp pro support
try visiting your laptops vendor website and download your driver for windows xp, just have patience or email me @ [email protected] and i will gladly help you download your driver
SOURCE: Compaq presario F500-Win XP not find Chipset? Lan, Wifi, nVidia ?
The HP site is useless but there is an ongoing user forum thread that gives many of the correct links to download F500 XP drivers:
http://forums11.itrc.hp.com/service/forums/bizsupport/questionanswer.do?admit=109447626+1230480164070+28353475&threadId=1115132
A partial list of the drivers from the chat is:
Download the Microsoft Universal Audio Architecture (UAA) Bus Driver for High Definition Audio from the following weblink
ftp://ftp.compaq.com/pub/softpaq/sp32501-33000/sp32646.exe
Dowload Conexant High Definition Audio Driver from the following weblink
ftp://ftp.compaq.com/pub/softpaq/sp34001-34500/sp34386.exe
Download NVIDIA GeForce Go 6150 Graphics Driver from the following weblink
ftp://ftp.compaq.com/pub/softpaq/sp33501-34000/sp33549.exe
Download NVIDIA nForce Chipset Driver and Network Controller from the following weblink:
ftp://ftp.compaq.com/pub/softpaq/sp33001-33500/sp33411.exe
Downlaod the Ricoh 5-in-1 Card Reader Host Controller and Driver from the below weblink:
ftp://ftp.compaq.com/pub/softpaq/sp33001-33500/sp33020.exe
Download Broadcom Wireless LAN Driver Drivers from the below weblink:
ftp://ftp.compaq.com/pub/softpaq/sp34001-34500/sp34152.exe
Download compaq Wireless Assistant software form the below weblink
ftp://ftp.compaq.com/pub/softpaq/sp34501-35000/sp34510.exe
Downlaod Conexant HDAUDIO Soft Data Fax Modem drivers from the below weblink
ftp://ftp.compaq.com/pub/softpaq/sp33501-34000/sp33890.exe
Download the compaq Quick Launch Buttons drives from the below weblink:
ftp://ftp.compaq.com/pub/softpaq/sp33001-33500/sp33258.exe
Download the compaq Pavilion Webcam Driver from the below weblink:
ftp://ftp.compaq.com/pub/softpaq/sp33501-34000/sp33544.exe
Download the Synaptics Touchpad driver from the below weblink:
ftp://ftp.compaq.com/pub/softpaq/sp33501-34000/sp33751.exe
Download AMD Processor Update for Microsoft Windows XP from the below weblink:
ftp://ftp.compaq.com/pub/softpaq/sp33001-33500/sp33499
If you have problems with individual drivers on thios list, refer to the chat thread as others may have found the correct drivers by now.
SOURCE: compaq presario c700 laptop
You may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
SOURCE: i dont no how to turn on my wifi or use my wifi on
Start by making sure your windows configuration is equipped with the latest updates. I installed a new hard drive in my computer and did a fresh install of XP. Once it was installed, I used the "Tools" tab on Internet Explorer to do a windows update. It took several cyles of doing this to get things worked through. For instance, Update won't offer the Service Pack 2 unless you've already updated to Service Pack 1. After 2 or 3 or more cyles of running Update and rebooting my computer, I suddenly discovered my wireless feature was up and running. Once it is actually in operation, you will need to configure it using the menus. I'll leave that discussion to another expert.
SOURCE: how to turn on wifi device on my compaq presario
go start->settings->network connection-> u see wireless network connection
right click and chose enable
