TV has no sound, no menu or input display, no picture. Only Blue screen when you turn it on. It also does have the red standby light. I also replaced the t-conn board, the main board and the power board and it is still blue. The model number is UN50J5200AFXZA Version #JD03 S/N: 04MY3CBH711145T
SOURCE: Black Bars on all blu ray movies
Hi icmjrtdr,
Having black bars displayed when watching a Blu-Ray disc is a common occurrence, even with a widescreen television.
You may have heard or seen aspect ratios of 4:3 or 16:9. 4:3 is the ratio of a traditional television that is nearly square. 16:9 is the ratio of most widescreen televisions currently marketed. The reason that even with a 16:9 television Blu-Ray discs are displaying black bars is that many of these discs contain footage that has not been reformatted for television. The screen in a movie theater is even wider than 16:9, and rather than trim the ends, most Blu-Ray discs maintain the entire picture.
Depending on the options available in your particular television, you may be able to find a zoom setting that trims the ends and removes the black bars. It is up to you if you would rather see black bars with the entire picture or lose a small amount of the picture on each side for a full-screen experience.
Hope this helps,
Jason,
Go Ahead. Use Us.
SOURCE: 42LG50 TV - Intermittant sound problems with blu-ray HDMI input
You say this doesn't happen on regular cable or when playing a regular DVD. Hmm. Is this Blu-Ray player connected by simplink? HDMI is a bi-directional format cable, so there are cases in setups where your tv can send commands to your blu-ray player and vice versa. It could be a problem with your blu-ray player that it is sending for some odd reason a mute command to your tv. Or is processing a command that your TV interprets to be a mute command when playing blu-rays. Because if it was the TV itself chances are you'd see this when watching a normal DVD or on cable as well. Since you say you're not, it leads me to believe the issue lies with the blu-ray player itself.
SOURCE: Problem w/Samsung BD-P1200 Blue Ray Disk Player
Hello mljackson197,
This indicates a problem with the pickup head. First I would suggest cleaning the laser head with a disk made for that purpose. If this does not work, then I would suggest (if you have a background in electronics) taking the cover off and checking the bias voltages on the laser pick head (comparring them to the schematic values). What I believe is happening is just a dust problem, however if it is a circuitry problem, contact the manufacture or use the schematic/service manual to locat OEM parts.
I would, however try to clean the pickup head first.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
SOURCE: Can turn on to red light and get blue light, but no picture
The mainboard needs to be replaced
SOURCE: I have a Tevion 32"
there is a firware update available from AWA
ernie.awa.com.au/TV/default.aspx
fixed my set with the same problem
cheers
I hope this helps.
If this Answer goes some way towards helping to resolve
your Query, Problem or Fault, please take the time to Rate it. Doing so helps
Solution Providers, like me, better understand the needs and the point of view
of Askers, like you, and guides us in exploring the best ways to provide the
most comprehensive, useful and high quality Responses and Solutions we can. If
you need further help, please do not hesitate to post another Question or add a
Comment to this Question.
Thanks for using FixYa.
