Question about Measuring Tools & Sensors
Sokkia cx105c error E880 - Measuring Tools & Sensors
2 Suggested Answers
SOURCE:
vogesclive
  • 873 Answers
SOURCE: we have sokkia cx107 giving error code e880 as switch on instrument. please give solution
https://www.manualslib.com/manual/1199954/Sokkia-Cx-101.html
Posted on Dec 02, 2017
The lcd displayed E190 error. i want to know the problem
The E 190 message means there is an error in the horizontal encoder. You need to contact the Sokkia service.
Apr 06, 2016 | Sokkia Set 610 Series Total Station Topcon...
E191 for total station, sokkia type, it does not observe horizontal and vertical angle & does not measuring
Sokkia total stations are repaired using Sokkia proprietary computer software. You need to return it to a Sokkia shop, no other shop will be able to corect this, not even Topcon (even though Topcon bought Sokkia).
Jul 29, 2015 | Sokkia CX-105, CX series, Total Station...
What is meant E024 error code of SET550X SOKKIA total station?
Hi Aung,
E024 is for F4 cal level error.
what this means is that one of the frequencies used in your distance measurement needs adjustment. This adjustment can normally be done as part of your annual service.
Not having it serviced for a long time is often the reason why these types of error will occur....
rgds, Paul
Jun 09, 2014 | Sokkia Set550x Total Station, Two Years...
Kobalt LDM-35 Err 208
signal too weak, change batteries. even though it may display them as good. as soon as i swapped for a fresh set of AAA error went away.
Mar 11, 2014 | Measuring Tools & Sensors
Error e191 sokkia 1030r
Sokkia 1030r displays e191 in horizontal angle window
Jan 19, 2014 | Sokkia Set210 / Set310 / Set310 / Set510 /...
Getting error code 279 on my Disto Classic 5a
can not measure distance.
each time the button is pressed dist, 279 error appears.
Aug 12, 2009 | Leica Disto A6 Laser Distance Meter
Sokkia PL 100 pipe laser showing error code
Hi I know it is 2 years too late but I thought I would write the solution for others
press the up the down and the on/off but all together after a few seconds CAL 3 will appear and the lser turns off.turn the laser back on again and it should be reset to 0.00 procent-you need to calibrate the laser now using the same method
hope this helps
Dale
Mar 21, 2009 | Measuring Tools & Sensors
Measuring Tools & Sensors Logo
184 people viewed this question
Top Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
