SOURCE: frigidaire electric range oven and top burners wont come on
It sounds like you only have one side of the 220v current coming into the range. I suggest checking the outlet feeding the range for proper power. The problem could actually be in your circuit breaker, only sending power via one of the conductors.
SOURCE: Frigidaire Gallery ES340 electric range, burners will not turn on
Okay,
1, check your power, locate your breaker for the range. turn the breaker off and turn it back on.
Your Range it is electronic control on the Oven but not the Stove Top heating elements.
After you reset the breaker and it still not work.
Please let me know more about the unit.
When you purchase.
How/when it happen.
What is the indicator showing.
[email protected]
SOURCE: DCS 4 burner plus griddle Range..oven doesn't heat
This happened to my DCS when the Hot Wire Relay went out. It isn't an expensive part, but finding someone that knows what needs to be replaced, and then can replace it is hard. My oven also did the opposite and continued to heat without shutting off, and it was once again the hot wire relay.
SOURCE: Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
