SOURCE: Swiss Army watch 70609 second hand pauses
Battery life indicater just warning to get that battery replaced so it wont stop at an inconveinient time
SOURCE: My Aquaracer second hand problem
This is most likely the "battery change indicated" feature of your watch. Change the battery, and see if the problem goes away. If it does not, then it could be a problem with the stepper motor, which will require a watchmaker. Of course all of this is dependent on the assumption that your watch has a quartz movement. If it is an automatic, or mechanical you have bigger problems.
SOURCE: second hand moves three seconds at a time
You have to replace capacitor in your watch. After that it will run like new.
SOURCE: second hand doesn't move for each second
Your TAG is fitted with EOL (end of life) feature. This is the cause of
that 4 seconds interval movement of seconds hand and thus indicating
the time for battery replacement. The timekeeping is not affected by
this- it is just warning to replace battery a.s.a.p.
Find your nearest watchmaker and ask for battery replacement.
Do not forget to rate, please.
SOURCE: My watch is keeping accurate
It is called the "eol" or "end of life indicator" Not yours! Your battery. Notice the time is still correct. This is a feature some better watches have to tell you your battery is about to go dead.
