The radio began making a screeching noise on all stations. AM & FM.
I unplugged the unit thinking it was damaged. The screeching got worse. I disconnected the battery and the screeching stopped.
I located a new battery. I set the date & time. I can not turn off alarm 2.
Does anyone know how to deactivate the alarm?
Thank you!
SOURCE: emerson clock radio cks 3516 military time
You will need to try some combination of the set button and time button to change the time back to normal time. Try hold both the time and set button for a period of 5-10 seconds and see if this will cycle the time to normal. If not try hold the set button alone for 5-10 seconds and see if this works. If not try holding the time time button for 5-10 seconds and see if that works. If none of the fixes work. Call Emerson customer support at this telephone number 1-800-898-9020 between the hours of 9am-5pm CT. Tell them the make and model number of your Clock/Radio and ask them for assistance with your problem of resetting the time back to normal from military time. They will be able to help you. I hope this information helps you solve your problem.
SOURCE: MODEL CKS 1855 BATTERY REPLACEMENT
Sorry it took so long to get you a answer to your problem. If you can not find the battery locally, you can find them on line. Just plug in the battery number in your search engine and it will bring up places you can purchase them. These battery are found in the larger electronic stores and drugstores and some large supermarkets. Places like Fry's Electronics. Micro center electronics, Rite Aid drugstores. I hope this information helps you with your problem of locating a replacement battery for your Clock/Radio. Than you for using FixYa and have a nice day.
SOURCE: I OWN A EMERSON RADIO AND CAN'T FIND MY MANUAL.
You can download and print the instruction manual in PDF format by clicking this link.
Adobe PDF Reader is required to view this manual. Download Adobe Reader
Hope this helps. Kindly let me know if you have any difficulty in downloading the manual.
Thanks for using FixYa.
