HP, not house.
SOURCE: PAPER JAM THAT REALLY DOESN'T EXIST
make sure the back cover (black panel) is fully closed. If it is, remove the panel and shake gently to make sure nothing has fallen inside.
SOURCE: paper jam 5610 hp
Please perform the steps in the following weblink.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c00441807&dlc=en&product=441125
Regards,
sagarjd
SOURCE: my hp officejet 5610 all in one keeps saying paper
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost,Scanner does not work, Connection problem etc. For find all these software solution just clickhere....
http://www.hp.com/printer/prob676ijt65/solution
ab47
SOURCE: HP 5610 all-in-one fake "paper jam"
I request you to please perform the below steps to reslove false paper jam..
Step one: Perform a partial reset
Step two: Perform a semi-full reset
CAUTION:
Performing a semi-full reset deletes any saved phone numbers on the product.
SOURCE: HP Officejet 5610 All-in-One continuous paper jam,
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
http://h30434.www3.hp.com/t5/Other-printing-questions/Paper-Jam-Error/m-p/305772#M20513
