Heating & Cooling Logo
Bhupen Patel Posted on Sep 21, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I try to plugin My Amana ptac it blow breaker .What could be the reason.
airconengr
Level 1:
New Friend:
  • Contributor 26 Answers
  • Posted on Sep 26, 2018
airconengr
Contributor
Level 1:
New Friend:
Answers
26
Questions
0
Helped
14183
Points
69
You have a shorted unit. Check the compressors, condensing motors, and the indoor fan motor. Replace defective parts found from the unit.
Henry S
Level 2:
Sergeant:
  • Expert 301 Answers
  • Posted on Sep 21, 2018
Henry S
Expert
Level 2:
Sergeant:
Answers
301
Questions
0
Helped
195121
Points
720
It could be the compressor, motor is shorted or grounded.
5 Related Answers
oscarn
Oscar Netto
  • 110 Answers
  • Posted on Sep 07, 2007
SOURCE: ptac fan keeps blowing
Try setting the fan control to "AUTO" this will cause it to cut out with the compressor.
Anonymous
  • 6 Answers
  • Posted on Sep 09, 2008
SOURCE: amana ptac shuts on and off constantly
your control board is shot and your ac can't tell the room is cold enough. 1-888-855-9987
Anonymous
  • 3 Answers
  • Posted on Jan 06, 2009
SOURCE: ptac not heating
the board or the heater need to be replaced
Anonymous
  • 142 Answers
  • Posted on Feb 12, 2009
SOURCE: Amana PTAC PTC093A35AA won't blow heat
The reset button is located behing a panel on the front of the unit that is labeled Heat Reset. If that label is gone then look around, it is a small hole, small enough for a paper clip to fit through.
That being said, I have 137 of these units in one of my hotels and have not had a single one needing to be reset. You probably are going to need a new control board kit. These can be purchased from Amana. They are $130. Make sure that you have pulled the heater coil out and inspected it first. Also, there was a recall years ago where Amana was supposed to contact and send out new voltage switches. These are the round black things that the Brown heater wires connect to on the upper and lower side of the heating coil. You should also try to replace those if you find the coil in good condition. I have had those resolve heating issues. Most of the heating issues were a result of a bad relay on the control board though.
Please remember to rate this fix.
Anonymous
  • 614 Answers
  • Posted on Jul 23, 2009
SOURCE: amana ptac- blows same temperature air whether its
Check to see if your compressor is running. Thre are 5/16 screws on either side of the unit holding it to the case. Take those out and you can get to the cpmpressor. These are not complicated units but you may have to have a service tech look at it for you. I do sell a lot of these PTAC units so if your compressor is running you have leak or bad compressor. Russ
Amana DigiSmart PTH153B50AM 14000 BTU Heat Pump. What Amana model replaces PTH153B50AM please?
Question edited for a lot more clarity.
The new improved energy efficient versions.
The Improved Amana R-410A PTAC Unit Uses Less Energy
Amana PTAC https://www.amana-ptac.com > products > ptac
Looking to buy an energy-efficient PTAC unit for your building? Buy the new Amana R-410A PTAC unit heat pump, which reduces energy consumption by 35%.
Probably this one. Talk to your installer.
https://www.amana-ptac.com/products/ptac/hec154j
1helpful
Amana Wall unit blows cold air before heating
The cold that you describe may be just unconditioned air? If you are certain you can hear the comp operating for a couple of minutes, and then the heat starts, I would guess it is a reversing valve issue if it's a heat pump and it probably is. Or the control board acting up. I've had a lot of issues with the boards in the Amanda PTAC units. I can't remember how to configure it, but if you Google "Amanda ptac configuration", there is a lot of info online. May try a reset method first. Hope this helps!
PTAC is not blowing cold air.
bad switch, bad motor capacitor, bad motor.
I have a Amana PTAC model PTC123A50AC never had any problems until this a.m. walked into office were installed no heat. Breaker tripped, reset breaker, nothing. Checked outlet, getting power. Any idea's?
To all friends! Whenever you find breaker tripped or fuse blown, it's an indication some device/s are in problem.
To get tripped breaker:
1. Condenser too dusty- clean it.2. Fan motor or compressor grounded-Replace. 3. Compressor high amps due to capacitor weak-replace capacitor. 4. Burnt wire-rectify. 5.Short circuit-rectify.
House wont cool ..tried to reset breaker in fuse box and breaker outside...this unit is only just over a yr old . the fan thing outdoors is not kicking on..
Does this unit have 2 breakers to it? The model you put down is a PTAC and generally just plugs in to the wall so it would have only 1 breaker. If I recall correctly it's got a 5 year warranty on parts so it may be worth it to check with your local HVAC tech and have them do a diagnostic for you. A good place to start would be Amana who can tell you the authorized service company in your area. They'll get the part for free and should roll the diag fee into the repair cost so you'll only pay for labor (if it even needs a part). Their sales and service number is: 1-800-647-2982. Here's a link to your warranty info:
http://www.amana-ptac.com/Home/Warranty/tabid/449/Default.aspx
3helpful
Ptac not heating
2answers
Top Amana Heating & Cooling Experts
Mike Cairns
Mike Cairns
Jay Finke
Jay Finke
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
