Question about Building Materials
How many sand and stone and cement do you need or cubic meter of concrete
  • Building Mat... Master
  • 3,947 Answers
A concrete mixture ratio of 1 part cement, 3 parts sand, and 3 parts aggregate will produce a concrete mix of approximately 3000 psi. (20685 kpa)
Posted on Sep 21, 2018
2 Suggested Answers
SOURCE:
raklein62
  • 360 Answers
SOURCE: 1.500 concret blocks 40cm x20cm in cement cubic
Max volume 4500_m^3 and smallest 24_m^3. I think you may want the smallest dia.
Posted on Sep 16, 2009
How much concrete in kg's do I need to concrete an area 3M x 3M x 125mm
Concrete is normally estimated in cubic metres
Convert all figures to metres and multiply
3 x 3 x 0.125 = 1.125 cubic metres
Plus 10% for shrinkage = 1.24 cubic metres
10 bags cement
0.7 cubic metres sand
0.86 cubic metres of stone
All assuming you want a strong mix
May 14, 2016 | Building Materials
Area of 8'x6'x4" into cubic metres
By your above measurements:
2.67 yds long 2.0 yds qide .11 yds thick for .59 total cubic yds or
2.44 meters long 1.83 meters wide .1 meters thick for total cubic meters of .45 this is reasonable considering the meter is longer than the yard so the total meter would be less..
May 26, 2015 | Building Materials
How many yards to cover 30ft/40ft 4 inches deep in concrete
That may be ok for the US, but in Europe you would need cubic metres.
I yd = 0.914 m, 1 cubic yd = 0.914 x .914 x .1914 = 0.764
So 14.66 cu. yds is 14.66 x 0.764 = 11.2 cubic metres - with a bit of luck!
Mar 26, 2015 | Building Materials
How many cubic meters of concrete will it take to pour a garage fool 336 sq feet 6 inches deep
Figure 1 90 lb. bag per square ft., 6" deep.
Don't forget sand to grade and rebar to reinforce.
You probably won't find enough guys to mix all that concrete, so you'd really be better off hiring a concrete truck.
Tip: It's best to over estimate a little so you won't be caught short.
Mar 01, 2015 | Building Materials
How do i know how many cubic meter of concrete pour in 50 squre meter and 50m
as in any volume calculation, follow this formula:
a x b x h = volume
a x b = area
h = height
all dimensions must be in same units, if you use m, all must be m, if you use ft, all units must be ft, use decimal not inches in imperial measurement.
in your example you give area of 50m2, you did not give what thickness of the slab, or should i assume this is 50m thick slab?!?
Oct 07, 2014 | Building Materials
Cubic meter calculator
Cubic meters defines volume. You must know how thick the cement will be cast to determine the volume. Therefore in this case 4 x 1.4 x thickness of the casting in meters = cubic meters required. Make sure the thickness is in meters (250 millimeters = 0.25 meters - divide millimeter by 1000 to get meters)
Jan 05, 2014 | Office Equipment & Supplies
What is the correct ratio for mixing concrete?
generally about 2:3 water to cement. it should say on the bag, if it is too watery add more powder, if it is too thick add more water
Jan 15, 2013 | Building Materials
1.500 concret blocks 40cm x20cm in cement cubic meters
Sep 16, 2009 | Office Equipment & Supplies
Building Materials Logo
80 people viewed this question
Top Building Materials Experts
Tom Chichester
Lawrence Oravetz
ray gallant
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
