SOURCE: c451 Bizhub Konica Minolta printer
press utility. press metercount. press metercount details. press stop 0 0 stop 0 1 to access service mode in service mode look for admin initialialation function
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
SOURCE: need written instructions on how to reset Ip code Konica bizhub C451
there are two ways you can rea\set the ip address you can press utility counter administrator password is 12345678 the go to network ip address and you can chane it there if you know the ip address you can browse to the machine and log in as administrator and go to network and reset there
SOURCE: how do you reset the konica minolta bizhub c451
Network settings are accessed through the Administrator menu. Press Utility/Counter, then choice #3 should be Administator Settings. Enter your admin password and Network Settings should be choice #5.
Also, if the bizhub is already on the network, you can enter the IP address into your web browser and log in as an administrator to get to the network settings.
