Your phone may have to be flashed to get it restored for active/continued use by you.
Flashing the ROM firmware erazes/deletes/cleans your phone of every passwords, data, downloaded media, messages, pictures, etc and restores it back like the moment you unboxed your phone from its pack/carton forntte first time.
Tools/materials you require are as follows:
1. A PC/Laptop
2. USB data cable
3. Internet access
4. Locked mobile phone
5. Flash tool "ANDROXYDE"
6. Lots and loads of patience (very important).
7. Plus, say, you can download YouTube video "Flashing Stock ROM on Sony Xperia (model name)"
Steps:
1. Take note of phone company to which your mobile phone is registered (not referring to your SIM card please). This is usually displayed immediately after tte Sony logo the moment you power on your mobile phone at startup.
WRITE THIS DOWN.
2. Download the Flash tool "ANDROXYDE" online to your PC/Laptop. It's a zipped file. Unzip it say to your desktop.
3. Download USB/Vcom drivers online so your PC and Sony Xperia phone can communicate. Install the USB driver(s) downloaded
4. Open the once zipped, now extracted into a folder on your desktop Flashtool ANDROXYDE. Locate the flashtool.exe folder and install it on your PC.Then, launch it.
5. Connect the UDB data cable to your PC first and leave the other end unconnected at first i.e. until step 6 is done.
6. Power your Mobile phone off and then connect the other end of the USB data cable.
7. Follow the tips as you have in the YouTube video...
1. A PC/Laptop
2. USB data cable
3. Internet access
Steps:
WRITE THIS DOWN.
Pls go to setting
go to SD card option
format the card.
Pls be sure that it will delete the content of your cell and in case you want to delete the softwares then you have to install a software called uninstaller from market and then you can delete the specific software that you want to....
I again say that you will loose all your data and hence better be sure that you want to do it,
It will erase to things you have saved of the phone itself but The stuff on you sd card will be fine, In this case I suggest installing the following free apps to save as many things as possible to you sd card:
some of the Go series of apps:
~ the Go Sms pro which backs up messages on your sd card (and Its customizable :) )
~ the Go Contacts which backs up contacts on your sd card (and again lots of nice features)
more info here and here
Then the ASTRO file manager app, which lets you look through all your apps but especially nice lets you back up all public (not just market) apps on your phone to your sd card
more info here
Hope this Helped, If It Did please leave a rating. and if you want more info I would be glad to be of assistance.
sir you can download the sonyericsson experia manual in www.sonyericsson.com in this website search your model and then download the manual user guide............
If you should see the warning message "CARD ERROR" in the LCD Display, please check the following:
Always choose reliable quality SD Cards. Toshiba Digital Cameras are tested for maximum performance with Toshiba SD Cards, Delkin SD Cards and Panasonic SD Cards. These are leading brands in the development of standard SD technology. Performance by other brands of SD cards may vary.
Check the LOCK switch on the SD Card. The camera can not save images to an SD Card when it is in the lock protected position.
If the SD Card is NEW, it may be necessary to FORMAT the card. This only applies to NEW SD Cards. If you format a card with images, all images will be erased. You can FORMAT your card periodically to maximize capacity and erase 'unseen' files, please be sure to download all images before choosing FORMAT as all images will be erased.
Your Toshiba Digital Camera is designed for use with SD Cards. MultiMedia Cards are similar in size and shape to SD Cards, although with close inspection you will find that SD Cards have a different 'PIN" connection configuration, are slightly thicker in size, and have a manual slide LOCK switch on the side. Toshiba Digital Cameras are not designed or guaranteed to accept MultiMedia Cards. Please be sure to look for SD Cards from Toshiba, Panasonic and Delkin, the leaders in SD Card Technology.
