SOURCE: I have a 3000 PSI Honda pressure washer. The motor
Your nozzle could be plugged or partially plugged. Also, try running it with the high pressure hose taken off to flush the pump.
SOURCE: I have a Ryobi 580030A pressure washer. I t was
The water seals are leaking thus pushing water back past the oil seals into the crankcase and mixing with the oil resulting in the grey ooze.So a new pump kit will have to be installed and the oil replaced.
SOURCE: Pressure washer worked fine and suddenly no
If you remove the tip, will it work? If so, unloader valve is sticking and needs to be removed and lubed with lithium grease.
SOURCE: Honda pressure washer, no pressure
sounds like you have a stuck pressure release valve inside the pump
