Sewing Machines Logo
B
Barry Tildsley Posted on Sep 20, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a new feeder dog for model #FY2300 Where can I get one? Live in the Vancouver area.
dannydoesita
Level 3:
  • Master 778 Answers
  • Posted on Sep 22, 2018
dannydoesita
Master
Level 3:
Answers
778
Questions
Helped
226648
Points
6375
With make and model # try sears parts direct.com. You should find what you are looking for. Good Luck Friend.
2 Related Answers
sylviaivie
  • 1564 Answers
  • Posted on Sep 17, 2012
SOURCE: feeder dogs not working
Are the feed dogs disengaged? Look for a slide switch or button on the back or on the front near the sewing area.
sylviaivie
  • 1564 Answers
  • Posted on Mar 20, 2013
SOURCE: The Feeder Dogs are not moving forward or backwards on my sewing machine.
Are the Feed Dogs dropped? Check your manual for the location of the switch. .... otherwise your mechanism has been compromised. Take it in for repair.
Singer sewing machine model 1425 feeder foot wont advance fabric
Not knowing this exact model or your history with this specific machine, I'll just toss out the following info.
If feeder dogs are not stepping, none of the following applies to your problem. Otherwise;
I believe the 1425 does not have dog up/down selection, therefor it uses stitch length zero (or about) to keep the feeder dogs below the needle plate when embroidery/darning.
Assuming feed dogs are stepping (rotary reciprocation), adjust stitch length toward a longer setting. Eventually this should raise the height of the feed dog step to a point above the needle plate thereby feeding the fabric.
So if choosing a longer stitch length feeds fabric, either the feed dog height needs adjusted, or something else has caused feed dogs to be lower than normal (additional repairs).
1helpful
I NEED A BOBBIN HOLDER FOR MY TINY TAILOR SEWING MACHINE. I LIVE IN THE VANCOUVER BC AREA OR THE WILLIAMS LAKE AREA.
We do not sell parts here, but any local sewing machine sales and service will have what you need or can get it for you.
Hi there looking at buying a yamata fy2300 can this machine sew denim? If anyone could help they would be great thank you.
According to this web site, it says the machine will sew everything "untill jeans" (sic). By that, I assume it means fabric lighter weight than jean fabric will work on this machine. In other words, sewing denim fabric may damage the machine.
1st Sewing Machines
Review results: Specifications Yamata model FY2300
and
Download your YAMATA FY2300 user guide or user manual
It may be a good idea to download a copy of the owner's manual and see what it has to say about fabric types the machine can handle.
1helpful
How do you know when the feeder dogs are up and down for futura 250
you can see the feed dogs in the needle plate area and be able to feel them with your finger
and the machine will sew a straight stitch when the feed dogs are in the up sewing position
if the feed dogs are down then the machine will not sew only stay in one position
Feeder dogs not working
My janome machine sews on the same spot, the material does not move. I have moved the feeder foot but nothing happens.Sometimes the feeder foot stays down.Idont have a manual for this machine.Igot it as a...
the feed dogs in the needle plate area are what moves the fabric while the presser foot hold the fabric
if the feed dogs are not up, check to see what position are in,,they should be in the bobbin area
if you can't move them they should be checked at a repair shop
My feeder dog is not coming up! it remains below the needle plate. Any suggestions? I am not very familiar with this machine. I took the extension table off and saw a switch on the back that looked...
The feed dog switch is on the back side of the machine, on the base. It is on the base, near the area of the needle arm. Try switching the setting of the switch
4helpful
3answers
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Top Sewing Machines Experts
SmartAviator
SmartAviator
Are you a Sewing Machine Expert? Answer questions, earn points and help others
