The unit should be sloped towards the outside per the instruction manual.
https://www.manualslib.com/manual/63687/Haier-Hwf05xck.html?page=11#manual
If you didn't ice up the unit the water should flow freely from unit. Is the filter clean?
SOURCE: Location of Drain holes on Duo-Therm Model 630035.321
Good place to start is up on the roof. Look way under the unit (hard to see some times) along the bottom, between where the gasket sits on the roof and metal bottom of unit. Should see small round or similar sticking down from unit. There will be a hole in the side of them. Poke around with a wire or something to open them up. If you don't see water/condensation running across your roof from unit when it's operating, (usually in 2 directions, 1 each side of unit) then yup, there plugged.
SOURCE: there is no drain hole for water to drip outside.
These are designed to retain some water in the pan. This is for the slinger fan to throw water through the condensing coil. This helps the refrigerant cool and is important to the efficiency of the unit. I would certainly not recommend drilling a hole in the bottom. The hole may cause the water to roll somewhere where damage could occur. Try instead tipping the unit Backwards before bringing it in the house.
SOURCE: Does Whirlpool air conditioner #
theres one near the back side on the outside part,they get plugged with bugs,leaves,debris,etc.,when its shut off look underneath and there is a drain hole on the bottom or on the rear ledge on either corner or both rear outside corners,make sure the unit has a slope toward the outside so most of the water drains there too,you can use a short piece of wire to clear these drain holes,if they are dirty enough you may need to unplug the unit and use a garden hose to dilute the debris so it flows out the drain holes
SOURCE: I have a sharp window AC unit, model af-609x.
All window air conditioners will remove moisture from the air if there is any. Most window air conditioners collect this moisture in the bottom pan of the air conditioner and attempt to evaporate the moisture. The evaporation process works as follows: First, the water drips down off of the cold evaporator coils on the front of the unit. Then the water collects in the bottom of the air conditioner base, the "pan." If the air conditioner is installed properly it will be tilted slightly back.
The water then collects near the back of the unit. On some units, the fan blade used to cool the rear condensing coils will have a rim on the outside of the fins of the blade. This rim, or "slinger," will come close to touching the inside of the air conditioner pan when the fan is spinning. As the water collects in the pan and reaches the depth necessary for the fan ring to touch it, the ring will lift some of the water up and the fan will blow it at the condensing coils. Because the coils are warm, they will evaporate the moisture to the outside.
While this is happening it is normal to hear water splashing and sloshing around. As long as there is no water leaking inside the room that is being cooled there is no cause for concern.
Never drill into the bottom of and air conditioning unit to "let the water out."
