Sewing Machines Logo
Astrid Asero Posted on Sep 20, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just purchased a pfaff 4870 everything looked fine until I started sewing and the needle shaft dropped can that be fixed it feels like it’s not secured . If it can be fixed how would I do that
Danielle Evans
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 4 Answers
  • Posted on Oct 10, 2018
Danielle Evans
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
Helped
238
Points
-There’s a lever for the presser foot pressure, turn it to “1”.
-On that piece the lever is on to the rear, there’s also a white plastic flat head screw, turn it and that will release that side cover. (You’ll kind of still need to pry it off, it seemed a bit like I was going to break the plastic, but it comes off).
-Once it’s off and the inside part of the needle bar is exposed, turn the handwheel until the needle bar is at its top dead center position, revealing a smaller flathead screw that will be just above the light.
-Either tighten or loosen that screw to move the needle bar to correct height, which leaves exactly 11.5mm between the tip of the over-edge needle B and the top edge of the needle plate. I put an arrow on the pic I posted of where the screw I’m talking about is.
Hopefully that helps someone and makes sense.
Just purchased a pfaff 4870 everything looked fine - 10_10_2018_3_27_09_am.jpeg
dannydoesita
Level 3:
  • Master 778 Answers
  • Posted on Sep 22, 2018
dannydoesita
Master
Level 3:
Answers
778
Questions
Helped
226851
Points
6375
Open the part of machine where the shaft is located. It is possible that the shaft is held in place with a fastener. You may only need to tighten what was not tightened at the factory. Good Luck Friend.
5 Related Answers
Anonymous
  • Posted on Apr 06, 2008
SOURCE: Hello, I have bought a
I did fix the jammed shaft - simply by applying some tenacious oil and letting it sit overnight. It is now a fully-functioning machine!
Thanks for your ear and your interest,
Cathy
lavon82931
La Von Beckstead
  • 17 Answers
  • Posted on Oct 14, 2008
SOURCE: needle won't grab bobbin thread
Check the position of the needle. Some machines have to have the needle in a certain way or they won't pick up the thread from the bobbin. Make sure the screw on the bobbin is tight but not to tight you may have to adjust it a few times to get it where it needs to be. Also make sure the bobbin is wound tight
Anonymous
  • Posted on Dec 31, 2008
SOURCE: can't open Pfaff Select 3.0 Sewing Machine to fix timing
I found an electric drill with a hex bit and that did the trick!
Anonymous
  • Posted on Dec 20, 2009
SOURCE: Pfaff 463 Industrial Sewing Machine needs Hook & Needle Re-Timing
ne sece konac
Dulwich hill sewingcentre
  • 23 Answers
  • Posted on Oct 20, 2012
SOURCE: Manual for a PFAFF 1222 sewing
you can try http://www.sewingmachine.com.au the can help you find this manual
How does the hook position lay inside the pfaff
the needle / hook timing has to be exact for the thread to be picked up
turn the hand knob on the end until the needle is at the bottom of the movement and is just about to start coming up
The hook of the bobbin case should almost be at the eye of the needle
The bobbin case hook is not adjustable as it is fixed on the drive shaft but the arm that drives the needle shaft is clamped on the shaft so by loosening off that clamp the needle and be moved to correct position
under normal sewing operations including broken needles , that timing seldom alters much so if it is way out then suspect a belt drive problem between the upper drive shaft and the bobbin drive shaft
It is normally a toothed drive belt that may have jumped a tooth in which case a trip to a service center would be in order
Hi I have a pfaff industrial zig zag 428, the bobbin has stopped all rotation
bobbin case should be stationary, bobbin itself is rotated as thread unwound, check hook timing. Simply turn hand wheel towards you and watch needle go down, when it reaches lowest point turn it slowly until needle rises 3/16" or so. Hook should be behind needle and slightly above eye.
I have a vintage PFAFF 30 sewing machine. I was sewing and the needle suddenly stuck down and wouldn't come up even when I turned the wheel. I tried everything i could think of to fix it. But I...
I recently purchased a Pfaff 30 with the sane problem. Local repair shop took it apart cleaned and oiled it and it's as good as new he charged 50.00 fir the repairs
1helpful
My pfaff 2170 says "main motor blocked" how can I fix this?
It happened to me... Check the bobbin and thread in the shaft ... Pull out the bobbin and remove all thread from the shaft. Pull out any thread remains with the tweezers. Check the feeder dogs and the needle (see Owner's Manual 2:7). Re-insert the bobbin (see Owner's Manual 2:12).Make sure that you use a good quality thread and set everything up correctly. Good luck!
Needle stuck in the material while sewing a straight stitch.
See if you can release the bobbin from the case.
Hello, I have a computerized PFAFF Hobblylock that doesn't work
My Pfaff dealer in CA gives free estimates. He recently took my sewing machine apart to determine that it had a bad board.
Top PfaFF Sewing Machines Experts
ExpressFiX
ExpressFiX
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
