SOURCE: Facebook was blocked from my computer and now i
When a site is blocked on a computer it means that the admin uses some kind of filter which bans that site, in your case Facebook.
The easiest thing you can do is to use a proxy. Web proxies are websites which intermediate between you and the banned site.
You -> proxy -> Facebook -> proxy -> You
This way you won't have to go to Facebook, which is blocked, but to the proxy which is not.
Here are the simple steps to accomplish this easily:
1. Go to Google and search "web proxies"
2. Select one of the links and go to the page of the Web Proxy.
3. On the page you should see an input field saying something like "Enter Your Adress here: ", or simply "http://".
4. In the input box type "facebook.com"
5. You should now have access to Facebook.
Hope this helps,
wbwTeam
P.S. If you encounter any further difficulties please let me know.
SOURCE: how can I unblock a friend on facebook
Your post is not so clear.Has your friend blocked you or have you blocked him?
I will answer you keeping both cases in mind.
If your friend has blocked you on facebook then it is not in your hands to get yourself unblocked. Your friend has to unblock you from his facebook profile.
But in case you have blocked him from your facebook profile then you can unblock him in the following manner. Go to your facebook site. Click on the 'Account' tab on the upper right hand corner of your website. Go to Privacy Settings - Block List - remove the name of your friend which will be listed there.
Hope this helps.
SOURCE: How to unblock facebook websites that been block
Edit your host file
C:/WINDOWS/System32/Drivers/etc
The file is named hosts
Edit with notepad and if you see a line that says
facebook.com 127.0.0.1
Delete it
SOURCE: i cant open the facebook website in the college
1st u go to internet option click on security option, click on restricted sites. remove facebook. from there.
SOURCE: how can i unblocked facebook blocked by our administrator?
You can't unless the administrator unlocks them. If he is smart he is blocking by sight IP or Gateway.
