Health & Beauty Logo
Kelly Forrest Posted on Sep 20, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Pride colt 8xl blue led light flashes 5 times then stops and flashes 5 times again and keeps doing this
Jeff Bird
Level 3:
  • Pride Master 1,348 Answers
  • Posted on Sep 21, 2018
Jeff Bird
Pride Master
Level 3:
Answers
1348
Questions
0
Helped
363440
Points
4615
Hi try this... cheers
Pride colt 8xl blue led light flashes 5 times then - img_20180921_171843-mgsk45vfevuycln0y5jl0ckh-2-0.jpg
5 Related Answers
A
Anonymous
  • Posted on Sep 07, 2007
SOURCE: Power up problem
One thing u can do also. Open your system case, remove cmos battery clean cmos battery and then insert like same. And restart your system. Other wise check power connections voltage. If it is ok then definitely it will wirk.
artifixit
Artur Rzasa
  • 59 Answers
  • Posted on Jan 27, 2008
SOURCE: CANNON IP5200
According to the service manual, that is an 'ASF (cam) sensor error' and solution being to replace the 'Sheet feed unit'.
Anonymous
  • 137 Answers
  • Posted on Aug 12, 2009
SOURCE: why flash by 5 times the orange led?
Probably your waste ink counter should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Good Luck, I hope this helps?!
Anonymous
  • 29 Answers
  • Posted on Sep 07, 2009
SOURCE: pride mobility Jet 3 Ultra Power Chair 7 flashing
a 7 Flashe code. There is a joystick fault. Make sure the joystick is in the center position and then power off and on again. Check all your couplings. make sure when turning on the unit you only mash the power button for 1 sec. 2-3 sec will put the unit in "Lock out mode".
This ierror will also be present if the joystick is off center when powered up. If you experience these symptoms, you must first make sure there is no physical damage to the joystick preventing it from returning to the center position. Then turn the power off and back on again (making sure the joystick is not depressed in any direction. If the joystick repeats this error, the controler much be replaced. [email protected]
Anonymous
  • Posted on Feb 21, 2010
SOURCE: power/standby led beeps red light 6 times
crazyford359
Your Thermal fuse is out. I just replaced mine, the part is only $4.85 on Sonyparts.com. Ordered (2)
2answers
Pride colt deluxe mobility scooter battery
The battery may be exhausted and in need of replacement.
1helpful
What dose red or yellow blinking lights on my jazzy pride electric power chair mean /
  1. VR2/VSI DIAGNOSTIC FLASH CODES
# OF LEDS
CODE
CAUSE
POSSIBLE SOLUTION
One red LED
Low battery voltage
Charge batteries
Two red LEDs
Left motor open
Make sure left motor is plugged into controller.
Three red LEDs
Left motor wiring fault
Contact your authorized Pride Provider.
Three red LEDs One yellow LED
Right motor open
Make sure right motor is plugged into controller.
Three red LEDs Two yellow LEDs
5
Right motor wiring fault
Three red LEDs Three yellow LEDs
6
Inhibit active
Three red LEDs Four yellow LEDs
7
Joystick error
Three red LEDs Four yellow LEDs One green LED
8
Controller error
Three red LEDs Four yellow LEDs Two green LEDs
9
Brake fault
Make sure both motors are plugged into controller.
Three red LEDs Four yellow LEDs Three green LEDs
10
High battery voltage
What if the speed LEDs on the VR2/VSI begin to flash?
  • Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, a charger inhibit feature keeps the power chair from driving. This is indicated by the VR2/VSI speed
    LED(s) flashing.
  • Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to
    activate.
  • Determine if all controller connections are plugged into the power base properly. If the 3-pin charger
    inhibit connector is not plugged in properly, then the charger inhibit feature will activate.
I have a Pride Sundancer that will usually go forward but not reverse. Green light flashed 3 then 5 blinks. What is the problem
Hi charge batteries & get them load tested ..U can buy a BATTERY LOAD TESTER of E/BAY cost aprox $36 this will give U an accurate reading on there condition,.3 flashe's unplug charger & turn key of & back on ..5 flashe's remove key push freewheel lever into freewheel & back into drive put key back & try it . Cheers
Hi, i have a pride colt xl8, it makes a continuous beep when switched on, status led is fine , not flashing to show a fault, how can i stop this beep?
Make sure the disengage lever is in the correct position. If it is, then the position switch on the lever is bad.
Pride colt plus mobility scooter light flashes 7 times battery fully charged frewheel lever in correct position and there is an audible continueous horn type noise but the scooter will not move
hi , 7 flashes mean the there is a issue with wigwag also known as the throttle lever now can you confirm the year of the colt please ?
Regards
Rob
Blue light on battery condition meter is blinking. It doesn't stop.
hi the blue light is indicating a fault, now count the flashes before a pause, or does it just flash all of the time ?
Please keep me updated.
Regards
1helpful
2answers
I have an xl8 mobility scooter that keeps cutting out and stopping dead, i then switch it off and on and it starts, could it be the motor?
My Pride Colt XL8 keeped cutting out (7 flashes of LED, Speed pot error) , checked all the cable connections up tiller arm as recommended by Pride technical support, worked for about a week, then problem returned. Eventually took to Pride dealer, with problem occasional occurring,they found it to be the lower tiller cable support bracket straining the cables connector intermittently and so removed the bracket, the problem then was solved !
2answers
Standby timer keeps flashing
HI,
Please count that how many times(count numbers) LED flashes in a specific time, and let me know, then i will be able to help you and can tell you the area of fault.
Hope you will understand my saying.
Thanks for using fixya.
6helpful
4answers
Dead Creative Zen M
Usually this problem is due to the firmware. When the firmware is updated to version 1.62.02, this problem usually will be corrected. The older firmwares have problems in recognizing the battery and allowing the battery to power the unit.
You will need a wall/AC charger for the operation. Plug in the wall charger and USB cable at the same time. Your Zen should power on when connected to direct AC power via the wall charger. Once it is powered on, connect the USB cable to your computer. Then begin the firmware download.
If your Zen does not power on when connected to the wall charger, your unit is dead and its time to replace it or get the motherboard replaced via one of the Repair services offered on this website.
If the upgrade button on the firmware window is not available, it is also time to replace your motherboard due to corruption of a chip on the board.
Top Pride Health & Beauty Experts
Rob Hill
Rob Hill
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
