Pets - Others Logo
Ashley Head Posted on Sep 20, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to split the casing of a Oster home grooming clipper
Chris Walker
Level 3:
Top Expert:
  • Master 1,573 Answers
  • Posted on Mar 11, 2019
Chris Walker
Master
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1245588
Points
21965
5 Related Answers
A
Anonymous
  • Posted on Mar 11, 2008
SOURCE: oster 76
There can also be a problem with the switch, which can be gotten to by unscrewing the the 2 screws at the end of the clipper . . .you must then test (with the thing unplugged!!!!!!!!!) to see if the switch wires are good or if the switch is broken by flipping the switch and or the toggle and then checking the wires with an ohm meter (easily available from radio shack or ?? for under 10 bucks or any kid who's into electronics. If the switch is good, when its turned on resistance goes to 0, if bad th switch shoes infinite resistance on or off . . .
If it hums and the motor is turning, but the blades don't move you need to replace the gear and or lever . . see this diagram
http://www.peasridge.co.uk/clipper-advice/clippers-products-oster-a5.shtml
Anonymous
  • Posted on Jul 15, 2008
SOURCE: oster clippers
Found another web site where some one had posted the information I needed. I just used Google search and found the information.
rggp
  • 22 Answers
  • Posted on Feb 02, 2009
SOURCE: oster 76 clippers
Here is schematic and instructions for service and repair. The model in the picture is the A5 however it is the animal version of the classic 76.
Anonymous
  • Posted on Feb 03, 2009
SOURCE: NEED PARTS FOR OLDER OSTER CLIPPERS
I gave it a shot and it worked!!!....
No need to bother with the universal guards. They looked bulky for the task, and after careful (visible scrutiny) decided to gamble on the "fast feed clipper" guides. Check them out here:
http://www.cache-beauty.com/oster0541.html
There are surely other people who sell them - you might shop around, but I bought from these guys. Warning, the shipping price is kinda steep. But like I said in my last post, I've tried other clippers and these are just the best. It was worth it to me.
Anyway, I am now confirming that these guards fit this old clipper brand of ours. Perfectly!
Anonymous
  • 448 Answers
  • Posted on Oct 03, 2009
SOURCE: Bought Oster Golden A5 clippers new but did not
There is a small gun-metal colored bar at the very rear, just below the back of the blade. It pushes inward, in the direction of the blade. Push it firmly in and pull up on the teeth of the blade. It should pop upward. You can then remove the blade from the tongue that it sits upon. When you want to put it back, slide the blade back on the tongue, then, WITH THE MOTOR TURNED ON, push the blade down to its seated position. It will click into place.
Terms regarding these devices are all too often assumed as understood. For most purposes, these are what you have to know for the A5 Oster. The cover plate is the part with two screws that has the name and other info on it. If you remove the two screws and the plate, you will see a nylon part that moves the blade back and forth--that is the lever. The other end of the lever, with a hole in it, is connected to a metal part called the link. Both parts are easily removed by simply pulling them upward from the device. The bakelite gear is the part that the link sits on (the larger hole in the link). It too can be simply pulled up off the metal shaft that it rides upon (careful not to lose the washer under it). That gear is turned by the armature gear of the motor (which is where things get much too involved to cover here, but from that point on the device very rarely has problems). Incidentally, the lever, the link, and the gear can all quite simply be replaced. They are available quite inexpensively at Amazon under Oster A5 Clipper parts (note that the one speed and the two speed take different bakelite gears, but the lever and the link are the same). If you were to replace parts such as these or simply lubricate them, remember that a good white lithium grease is recommended in light application for the gear and the shafts (lever and gear shafts and armature gear). Also, the gear shaft has a hole down its middle (and two small holes that lead to the outside of the shaft. The shaft should be filled with grease so that grease can get through those small holes to lubicate the inside of the bakelite bearing. The two pads (one on each side of the lever) should be oiled. The simple way to tell if you need to replace parts is to grip the blade end of the lever while all parts are in place and try to move it back and forth, as though it were running the blade. If there is any more than the slightest movement, replace the lever (replace that anyway if the part that contacts the blade is rounded off) link and gear.
Good luck.
Is there a tool to get the Motor housing back into the A5 clipper case.
No special tool you need to make sure you have removed the gear wheel in the gearbox, locate the armature inside the motor frame first then slide the motor housing complete with the armature into the body of the clipper sometimes you may need to twist a little to get it in. I have put a link below so you can see the parts I have mentioned.
http://www.angliaclipperservices.com/Clipper_Parts/Oster/A5_Golden
The brand new gear lever on my oster a5 isnt moving the clipper blade
make sure the blade is clicked into place fully, secondly check to see if the blade is sitting further away from the clipper than usual, it could also be a stripped gear inside the clipper does the lever move when the blade is engaged?
Oster blade no. 913-50
http://www.ebay.com/itm/Oster-Blade-Set-913-50-Fits-Fast-Feed-17-tooth-76913-506-New-/130803957423
120v plugged in 220v
oops, you may have blown the circuit board or possibly the motor either way its not going to be a cheep fix. 120v clippers are not ment for 240V
2answers
Does someone know which # blade to use with the Oster, universal comb set for use with the Oster A5 turbo clipper?
Hi, as far as I know you're suppose to use a size 10 or 30 blade with any combs. I prefer to buy a longer blade like a size 4 rather than using the combs as I find the coat finish not great with the combs.
Oster clipper
It sounds like a faulty motor if they are under a year old send then back who you purchased them from otherwise it could be a costly repair.
Dog Clippers
Oster A5 clippers work briefly then "pull" hair
Lever arm worn, blade blunt, or loss of movement inside the gearbox. It is possible to have a 'bad' sharpen.
Oster A5 clippers
Let Oster sort it out under guarantee. If you mess about you are likely to kill the guarantee.
Top Pets - Others Experts
Kardoc
Muhammad Tanveer
Sierra
Sierra
Level 1 Expert
Are you a Pets - Other Expert? Answer questions, earn points and help others
