Hardware & Accessories Logo
K
Kelley Humphries Posted on Sep 20, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I recently bought a home with an orbit in ground sprinkler system. How do I turn on each station manually from the control box to evaluate the sprinkler layout?
Charles Houlroyd
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 124 Answers
  • Posted on May 19, 2019
Charles Houlroyd
Expert
Level 2:
New Friend:
Cheetah:
Answers
124
Questions
0
Helped
65134
Points
268
Here is the location of Orbits Product Manuals
https://www.orbitonline.com/help_center?stPage=guideListPage-1
Hope this helps
5 Related Answers
mydogisk
Kenneth
  • 50 Answers
  • Posted on Apr 13, 2009
SOURCE: Solenoid on one station, sprinklers on another, cant turn both on
the should be a pump or master solenoid connection inside the controller
protek480
Craig Butler
  • 1730 Answers
  • Posted on Jul 02, 2009
SOURCE: Orbit sprinkler system
Have you programmed the new one with all the info for date and time? Did you set the zones for the days you want and watering times?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
appman67
appman67
  • 33 Answers
  • Posted on May 16, 2010
SOURCE: i need a user manual for the timer box of a orbit
http://orbitonline.com/support/guides/Manualsearch3.cfm?Brand=02&Type=Timers
Anonymous
  • Posted on Jun 23, 2010
SOURCE: I have an Orbit WaterMaster Sprinkler control, it
There are 3 things this "off power" "light bulb" could be. Blinking red light? means fuse has gone out. Check the power source where the unit is plugged in to. Is the GFI popped out? plug something else like a fan or something into the socket to test. the third thing is a short internally. Call orbit technical assistance. they're great.
Anonymous
  • Posted on Aug 22, 2010
SOURCE: can i get online instructions on how to program my
moved into house with 4 station Orbit sprinkler unit. Manual is faded, cannot figure out how to get it to control the sprinkler system. Can I get online instructions on how to program it?
I have an Orbit 9 Station Sprinkler System & the manual watering feature isn't working. I replaced the 2 AA batteries & the fuse in the control box but it still won't come on. Can you help me?
Based on my knowledge of Orbit branded products like yours your timer has failed and you need to replace the unit with another more reliable brand. Orbit has real issues with their designs.
Getting sprinklers to come on
Is it a one way valve? If so you may need to turn it around, if it was just installed from new... make sure that the dust caps are not inside the valve and obstructing the line
Orbit sprinkler timer manual
Contact the manufacturer. They usually will have the manual online for downloading.
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/support/
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
1helpful
2answers
Can i get online instructions on how to program my
5helpful
2answers
I have an Orbit WaterMaster Sprinkler control, it is hooked up, but there is a light bulb that says power off and the sprinklers won't turn on. They will turn on manually at the sprinkler station. Can...
Top Orbit Hardware & Accessories Experts
Paul Carew
Are you an Orbit Hardware and Accessory Expert? Answer questions, earn points and help others
