I'm trying to print documents from laptop. Printer recognizes it, goes through the whole process. l can hear the ink jets moving but it spits out blank paper. l have done a full clean of printer and the heads and there is plenty of ink. Can anyone please help. Cheers Donna
When a user using the old cartridge then they can be facing this type of errors. Mostly it is a hardware issue responsible for this error. If your software and driver bed then your hardware can go into a bad condition. So you should fix this error quickly YOu can fix this error by Unclog printer head, USe another software and Update printer drivers Because outdated printer drivers can be missing up your printers command.
https://www.errorsdoc.com/epson/fix-when-my-epson-printer-printing-blank-pages/
Are you confused what to do if your printer spits blank pages? Try the following solutions. Ensure that you have selected the correct paper size under the Printer Properties in the printer software. Clean the print head using the software installed on your computer to check whether the nozzles are clogged. If the problem continues, open the Printer Preferences on your computer and select Skip Blank Page to stop printing blank pages.
Step 1: Click the Start menu and select the Devices and Printers option.
Step 2: Right-click on your printer model name.
Step 3: Open the Printing Preferences category and select the Maintenance tab.
Step 4: Click the Extended Settings button.
Step 5: Enable the option called Skip Blank Pages.
Step 6: Click OK to confirm the changes you made and save your settings. To Get Instant Support Call our Toll-Free 1-866-293-9220
How do l fix that?
