Question about Precor Exercise & Fitness
My Precor efx 546 elliptical I have power but it won’t recognize that I’m pedalling. Any ideas?
  • Precor Master
  • 1,642 Answers
3 Suggested Answers
SOURCE:
SOURCE: looking for repair manuals and error codes for
Could you please advice about ERROR 29 fo C956i/C966i treadmill.
Posted on Mar 04, 2010
info95456
  • 10 Answers
SOURCE: My Precor EFX 5.17i elliptical trainer keeps displaying "Error 40" even when I turn it off and back on. How can I fix it?
This is an incline error. Check fuses and incline gear for jammed incline. Call 877-805-1030 or www.techmotionusa.com for service tech if you still need help
Posted on May 09, 2015
Can I adjust the stride length?
Precor EFX 546 Version 1 Elliptical Trainer (Refurbished)
www.amazon.com > ... > Elliptical Trainers
Amazon.com, Inc.
Rating: 4.3 - ‎9 reviews
Working out on an elliptical can burn as many calories as working out on a treadmill. ...allowing you to go forward and backward, as well as adjust stride length to target ...The Precor EFX 546 allows you to stride smoothly while holding the ...
EFX® 546i Elliptical Fitness Crosstrainer™ ' Precor
www.precor.com/en-us/.../efx-546i-elliptical-fitness-crosstrainer-33
With the unique Precor CrossRamp® technology, users can alter the path of the EFX®546i between 13 and 40 degrees in both forward and reverse stride motions, cross ...Excellent stability and freedom of movement for users of all sizes.
FAQ - Precor
Dec 28, 2015 | Precor 546 Elliptical
My precor efx 546 makes noise like a squeaking in left pedal it seems I tried to tighten pedal but I the whole bolt and screw turn together and the other pedal makes no noise
This squeak is normally caused by a bad bearing in the wheel. In order to provide you with the correct wheel, I will need your serial number. The following link will take you to our Precor EFX 546 page.
Repair Parts for Precor EFX 546 Ellipticals SPORTSMITH net
May 29, 2014 | Exercise & Fitness
Precor efx 546 wobbles when raising incline
It may be either the front shroud is installed incorrectly or broken, or the corkscrew for the incline motor is bent. If it is bent, it would need to be replaced.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/russell_1d1c35fa8a5a0be4
Feb 10, 2014 | Precor Efx 546 Version 1 Lower Body...
Service manual 546
Repair Parts for Precor EFX 546i Ellipticals SPORTSMITH net
Please use your model and serial number to narrow down your search. In the middle of our Web page you will find the service manual for your machine.
Sep 03, 2013 | Precor EFX 546i Elliptical Version 4
How to repair a 546 efx precor
Assuming the buttons are working, the numbers change on the display, and the incline works, it may be the lower circuit board or the generator. If it is a very old unit, it may be the electromagnet or the data cable that connects the two circuit boards.
May 08, 2013 | Precor Efx 546 Elliptical Version 2...
Can't find the serial number -- there is no tag or it has been removed. It's a precor efx 546, MANUAL not electric and I either need a new battery or a battery charger. What do I do without the serial...
Precor Serial # Locations Type of Unit Serial # Location Treadmills Located on the label near the power cord entry and on the frame under the left rear of the treadmill. Upright Bikes Located on the front stabilizer. Recumbent Bikes Located on the front stabilizer. Ellipticals Located on the front stabilizer. Stair Climbers Located on the bottom side of one of the foot pedals. http://www.sportsmith.net/
Jan 22, 2011 | Precor EFX 546i Elliptical Version 4
My precor efx 544 has stopped recognising that i am using it. does not display strides or calories burned. any ideas?
My Precor Elliptical EFX 546 Timer Stops After 7 Seconds, what is wrong? The most common cause for the Timer to Stop After 7 Seconds on a Precor Elliptical is NO RPM Feedback.
Knowing the status of the unit from its last use as well as the last service or part replacement is a great place to start.
Check the connection of the speed sensor to the lower board. Reset connection if necessary.
Check the magnet. The magnet is located on the user's right crank arm on versions 1 and 2 and the user's left on version 3. The magnet passes the speed sensor with each revolution of the crank arm. The magnet should be installed so that its south pole is facing the speed sensor. You can check the magnet polarity with another magnet that has marked poles or a compass. The north pole of the marked magnet or the south facing needle should be attracted to the magnet. Correct magnet installtion if necessary.
You may also check the spacing of the speed sensor to the magnet. The spacing should be 1/8" to 1/4". Adjust if necessary.
Also see the following link for additional information.
Replaced Crank Arm on Precor EFX 546 and Display Doesn Work
Jan 14, 2011 | Precor EFX 546i Elliptical Version 4
Error 45 on Precor EFX 546 Elliptical
Precor Error 45, Lift Moving in Wrong Direction Probable Cause 1. Lift motor hysteresis.
2. Lower PCA is bad.
Corrective Action 1. The error would usually occur when the lift was already in motion (usually downward) when a lift command in the opposite direction (upward) was made. Some lift motors used in production exhibited a very long turnaround time and the lift motor would still be moving in the original commanded direction while the control system was trying to move the lift in the opposite commanded direction. If the error continues to re-occur, replace the lift motor.
2. It is a rare condition, however if the lift moves in the opposite direction commanded, replace the lower PCA.
Precor Error Code 45
Jul 19, 2009 | Precor EFX 546i Elliptical Version 4
Exercise & Fitness Logo
94 people viewed this question
Top Precor Exercise & Fitness Experts
Jose Pino
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
