Measuring Tools & Sensors Logo
Kathy Chase Posted on Sep 19, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I changed the batteries in both indoor and outdoor units of my 1099RX. Everything is correct except the time. Please tell me how can I set the time?
Marvin
Level 3:
Top Expert:
  • Measuring To... Master 85,242 Answers
  • Posted on Sep 19, 2018
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29024993
Points
266281
I have no idea what this 1099RX is.
5 Related Answers
Anonymous
  • Posted on Nov 20, 2008
SOURCE: model 6312026 Nexxtech 433MHz wireless
Hello, you have to push few second the mode button and after date, hour etc it will be possible to change F for Celsius. He will flashing and after push one of the two button up or down.
Bye from Quebec Canada
Anonymous
  • Posted on Apr 25, 2009
SOURCE: ac split unit indoor an ouydoor unit electrical wiring diagram
machine off
Anonymous
  • 1902 Answers
  • Posted on Jun 01, 2009
SOURCE: Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
Anonymous
  • 81 Answers
  • Posted on Jun 28, 2010
SOURCE: U4 System transmission between indoor and outdoor units Daikin
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps I take the time to answer your question so please rate me
hvac1960
R Subramaniyam Iyer
  • 2133 Answers
  • Posted on Jan 03, 2011
SOURCE: indoor unit flashes 5 times. error code meaning?
E-5 -Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
My smartgear weather station is working fine for everything except outside temp and humidity.
The indoor unit batteries are weak and not collecting data from the outdoor unit. My indoor unit battery need replacing every 6 months, and I replace the outdoor battery every year. I buy Amazon Basis CR2032 in packs of 5. Yours takes AA Lithium Batteries.
https://www.amazon.ca/Smart-Gear-Outdoor-Wireless-Weather/dp/B015U5V7RO
A/C Unit SAMSUNG -Outdoor unit model= MH080FXCA 4A was connected to 3 indoor units:
It's possible you have a bad data wire on one of the systems. Swap the data wire or both if two with a different wire. (1&4--2&3) whatever. Whatever you do inside obviously do outside. Might have extra resistamce that is throwing the error but will be fine for a ground wire.Or do one system at a time, being sure to change your dip switch settings until you figure out the problem unit. Good Luck!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
2answers
Model 1099rx not working,even after I replaced all batteries
If this is for the AcuRite weather station, please contact customer support at: http://www.acurite.com/support
I have a walk in freezer with 404a, I am reading about 25 on the low side,the outside temp is about 110 degrees,its not low on freon,and everything seems to be working fine, except I cant get the temp down...
What is the high side pressure?
Are the indoor and outdoor coils clean?
Indoor and outdoor fan motors working OK?
Ice on the coils or expansion valve?
Is the unit sized correctly for the space?
Top Measuring Tools & Sensors Experts
Steve Pack
Steve Pack
ADMIN Andrew
ADMIN Andrew
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
