Konica bizhub C351 copier I thought a C9401 error code was related to the exposure lamp not turning on.
When you turn on the machine it comes up with a C9401 error code. We are aware that this could be associated with the exposure lamp, but since the exposure lamp uses a HV transformer what is the best way to test this area? Also what else could be the problem?
Any help would be greatly appreciated.
The output from the CCD Sensor is a predetermined
value or less during CCD Sensor gain
adjustment.
Check the flat cable for proper connection and
correct or change as necessary.
Change PWB-C.
The original glass is removed from the machine or the white reference strip is damaged.
Ensure that the original glass is installed properly on the machine and the white reference strip is correctly positioned. Replace the original glass as necessary.
