SOURCE: Dishwasher tripping the circuit breaker
Andy, leave the breaker off and remove the toe panel (bottom panel) from the dishwasher. Remove the cover of the junction box where the cord connection or wiring is made. Look at the wire caps and see if they are not burnt. Sometimes these connections become loose and arch, tripping the breaker. If so, cut the wires, strip a new end and reconnect. Catriver...post back.
SOURCE: whirlpool electric dryer keeps tripping main circuit breaker
First off, be sure the pigtail is wired correctly to the back of the unit. Black and red to the outside terminals, white to the middle, green to the frame or cabinet (should be a green screw close-by). If that is ok, you probably have an issue with possibly a bad pigtail, bad outlet, wiring issue, or possibly a bad circuit breaker or breaker box. Probably going to be more of a electrical problem than a appliance problem. Good Luck!!!!
SOURCE: getting no heat in my whirlpool gold ultimate care 2 dryer
It sounds like you blew a Thermal fuse on the heating element open the back unplug and on the right side you will see towards the top of the heating element 2 red wires check with a metter to see if good also pull the wires off the element at the bottom to check it let me know
SOURCE: LG washing machine trips GFI Circuit Breaker
WASHING MACHINES ARE NOT TO BE CONNECTED TO GFI OUTLETS AND TRY TO CONNECT IT TO A CERCIUT THAT IS NOT WITH YOUR DRYER. (REG) OUTLET.
SOURCE: Photocell and circuit breaker
Hi, Here is my clarification of the instructions for you. The photocell must be protected by at least a 10 amp circuit breaker. The photocell may be installed next to the light fixture. ( not the breaker). Good Luck, this should Fixya!
