see this step and fix it. God bless you
Unplug the treadmill. Locate the console key and place the
safety or reset key into the treadmill console. Replace any parts that
need replacing, or move on to the next step.
Locate the reset switch on the underside of the treadmill
console. Usually the button is large enough to trigger with a pencil
eraser or Q-tip. Plug the treadmill plug back into the wall. Use the
Q-tip to press the reset button. It may be necessary to hold the reset
button down for a few seconds. "CL11" will appear in the display of the
treadmill.
Press the reset button one more time with the Q-tip. "CL21"
should appear on the screen. Press the enter key. The display will
change again and show "CL22." Keep pressing the enter key until the
numbers cycle through to the number "CL26." Press enter one more time.
The letter E should appear on the display screen.
Press enter twice more. The letters "SS" should appear on
the screen. When this happens, press the start/stop key. Making sure to
keep well away from the tread, press enter to start the treadmill. The
treadmill will start on its own. The treadmill will stop on its own
after a few seconds. When it stops, press the power key two times.
Remove the safety key and put in a safe place. Your treadmill is reset.
treadmill.
1) Display does not illuminate when machine is powered on. Insufficient power source. Plug treadmill into a dedicated amp circuit.
2) Loose 10 pin connection at display console or wax/lift control board. Check all electrical connections for proper attachment.
3)Damaged main harness wire connection.
4)Replace wire harness. Faulty display console or Wax/ Lift Board. Verify if 8VDC is present at P1 pin, 3-4 and 12VDC at P1 pin 9. a)If yes, replace Display Console.
b) If no, replace Wax/Lift Board. See How To... Replace Wax/Lift PCB.
Use VOM digital (Voltimeter)
Hoping that you can resolve, if you need some extra help, please reach me.
two possible issues one, unplug treadmill remove hood and make sure the main power connector to the motor control box is in properly then turn treadmill back on this has worked for me before two , you have blown the overload resistor on the motor control board (mcb) to check this unplug treadmill and remove the steel motor control box from under the hood remove the motor control board from inside the box and inspect it for damage and /or electrical burn smell if you find damage you will need to get it repaired contact glide fitness products in santa ana california 1866 637 4600 for all information including shipping . it cost $200 plus shipping which is a deal since a new one is $1000,i have many repaired by them a common issue for the overload to blow is friction between the belt and deck board . if you have an auto waxer , the waxer nozzle is usually plugged . the nozzle should be cleaned once a month contact glide for their non clogging wax to resolve this issue good luck
usually this means your motor control board (mcb) is damaged . remove the motor control box from under the hood remove the mcb from the box and check for damage and/or electrical burn smell . there is an overload resistor that usually blows up this is due to an overload caused by the issue you described or too much friction between the belt and deck board . if damaged you will need to get it repaired contact glide fitness products in santa ana california 1866 637 4600 for all details, i have had them repair many of them , it cost $200 plus shipping which is a deal considering a new one is $1000 if you need to send it for repair , remove the wax board and small electrical componet on outside of box and put in a safe place as you will need to reinstall them on new box if this is caused from too much friction and you have an auto waxer the waxer nozzle is plugged clean this nozzle once a month or contact glide regarding their non clogging wax good luck
remove the motor control box from under the hood, there is the motor control board (mcb) and capacitors inside the box remove the mcb and check for damage and /or burnt electrical smell also inspect condition of capacitors (4 round cylinders) if this is the cause you need to get the board repaired contact glide fitness products in santa ana california 1866 637 4600 for all information including shipping details i have had many repaired by them .the cost is $200 which is a deal considering a new one is $1000 the most common reason for mcb's burn up is a resistor blows due to overload caused by too much friction between the belt and deck board ,and that could be the result if you have an auto waxer nozzle that is plugged up . these nozzle should be cleaned out once a month note that glide has a non clogging wax to eliminate this issue you ask them about this as well if you have to send out for repair , make sure you remove the wax board and small electrical component on outside of box and keep them in a safe place as you will need to reinstall them on the new box good luck
hit the stop button and hold down pouse key until the counsel repowers up and tougle throug to mantinace enter then tagel throug to waxer refill and hit enter
you will need to go into service menu by pressing and holding the pause button then pressing the clear button twice , continue holding the pause until the service menu appears. then use the arrow up and select maintenance press enter then either use arrow up or down scroll and say refill waxer system or replacing wax bag press enter, this will reset upper console. Upon completion of this the go back into the diagnostic menu select system test press enter scroll up or down to waxer manual mode hit quick start and that will fire up the wax pump and your done
Does this treadmill have a wax system ? If it does it will have side access panels on the side just above the rear leveler. The picture that shows here does not but need to be sure it does not really need wax.
If it does not have a waxer- enter maintenance settings on display console,I do not have one in front of me but I believe you hold pause button down and press clear twice. This should bring up maintenance settings.
Scroll using up down arrow untill you see replace wax bag or something to that effect. select [enter ] to save. press clear clear to restart.
