Frigidaire FRS26R4C Side by Side Refrigerator Logo
Posted on Nov 25, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My admiral fridge freezer suddenly stopped working -
Admiral Fridge Freezer (side by side)
GC2224GEKB SERIAL 11243032JG The repair man discovered it would only work when the fridge door was open so said we needed a new control board. He isolated the door light switch and the fridge and freezer both work now. We sent for a new board (Maytag board control 67006740) but once fitted, it won't accept the program code. There is a little sticker on the original board "Jazz 13" but the replacement board has "Jazz 14" on it. is it the wrong board or is the problem elsewhere - anyone any ideas please??
I also have the problem with the fridge freezing over and Maytag told me just to blow a hairdrier on the cold air inlet from the freezer. It was only a month old the first time it did this and has done it again several times. Can't leave anything in the fridge when we go on hols for fear of it all freezing up! It's out of warranty now and maytag want a fortune just to come out and look!
  • 2 more comments
  • Fedupsville Nov 26, 2007
    Thanks For the reply Dr - this is what we did
        Hold fridge doorlight switch down and push freezer control(-) down 3 times consecutively
        Release door switch - display shows P;E
        Press freezer down once more to confirm
        Display shows 0:0
        Press freezer & fridge (+) keys to show code (2:8) All OK to here
        Once correct code shown press freezer down (-) key until code begins flashing to show confirmed - this is where it returns to 0:0 and flashes.
    The people we purchased the board from have also confirmed it is the right one but suggested as follows:
    "Have you checked the evaporator motor for any faults (in the freezer)? The evaporator motor if faulty can damage the board. Have you checked the old board for damage? "
    We don't know how to do this but as the Frd/freezer is working OK with the old board as long as the light in the fridge is isolated, can only assume it's ok - how do you tell if the board is damaged - is it obvious?
    On the other point re freezing up - would appreciate any info but as we have just paid £80+ for a new board, would like to get that working first if possible.
  • Fedupsville Nov 27, 2007
    Thanks again - we will try 25 but it definitely says 28 on the inside of the fridge - worth a try though.
  • Fedupsville Nov 30, 2007
    You star!! Looks like code 25 did the trick despite the plate saying code 28 - and all seems to be well. Thank you very much Dr.
    no longer "fedupsville"
  • davelk Dec 17, 2007
    Same problem, different fridge (Amana AFB2534DEW). Code was programmed into unit correctly, but fridge won't run. Is there another step after this to get it to start back up?
Anonymous
Level 3:
  • Master 447 Answers
  • Posted on Nov 25, 2007
Anonymous
Master
Level 3:
Answers
447
Questions
5
Helped
355749
Points
1420
I took the time to look up your Model # and you do have the right board. Jazz 14 Should just be a revision one higher than your origional. Describe to me exactly what happens when you try to program it. You may be missing one little step. Make sure you are doing every step exactly right. I too can miss one little confirmation stroke and it seems like it wont work. I Can email you the tech sheet for your model. This will show you how to test all the sensors, and the damper to determine why the FF side is getting too cold. I will also help on my end as much as i can
  • 2 more comments
  • Anonymous Nov 26, 2007
    Ok upon further review i see you are doing everything correct and by the control flashing 00 at the last step it is also telling me the board is ok because that is what it is programmed to do if you try to enter the wrong code. I want you to be absolutely sure, the program code is 28.It 25 it shows 25 on my online tech sheet. Not saying that is the right code, just try it and see if it works proper. I think that your fan is ok too since it was freezing everything that definatly means it was working it would be the opposite if it werent. I can email you the tech sheet to put it into diagnostice to test the fan, the thermisters(the temp sensors), damper assy(the part that stops the cold air from coming into the FF when it is cold enough),and the compressor and cond fan
  • Anonymous Dec 01, 2007
    Im glad that I could help. I may try and contact Maytag about this and see what they say. Ill let you know if I can reach them.
  • Anonymous Aug 18, 2012
Admiral side by side, freezer working, fridge not getting cold
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
My frost free, Admiral, side by side freezer just stopped working, i plugged it out for two days and when i plugged it back in neither the freezer or fridge works. Its actually warm inside both sides and i...
Whoops
The fridge has a refrigerant leak, or the thermostat has failed.
Try replacing the thermostat, if that does not work then you will need to call a technician in to find and repair the refrigerant leak and regass the fridge
2helpful
I have a black admiral fridge( freezer on top, not side by side) the vents on bottom of freezer froze with ice and fridge stopped working completly
the evaporator coil or freezer coil need for flushing due to clogging on vents have a presence of oil need for reprocesses and charging of refrigerant after refrocessing.
1helpful
Admiral SAC224GB Fridge freezer has stoped working
when did this happen... could be your compressor out on overlaod... leave it for an hour or so try them, if not your compressor could be gone.. or fingers crossed its just the start capacitor for the compressor...
Admiral GC 2027 HNKBS
Hi i had the same problem, if you ring Maytag on 08444990101 they are the uk supplier for admiral fridge freezers. hope this helps
Admiral side by side fridge defrosted and no longer cooling
Replace the compressor start relay.
If this does not solve the problem you most likely have a bad compressor.
Your fridge may be under a 5 year compressor warranty.
My fridge freezer has stop working but if you open the door it start to work but if you shut door it stop's and you can hear the fan in freezer stop and start it's a admiral gc2224gekb side by side
Hi thanks for te question. it should be the opposite of what its doing did somebody work on this fridge before. it looks like somebody switched the light and the fan switch
3helpful
Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
All the cold air from your freezer gets pushed into the fridge with a fan in your freezer section. So your problem is from the fact that this cold air isn't get to your fridge.
- the door that allows this cold air into the fridge, normally in the top left corner of the fridge, is stuck shut and needs replacement.
-the freezer isn't defrosting and restricting the air flow
-the temp controller for the fridge is damaged and thinks that the fridge is cold enough.
Top Frigidaire Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
