Question about Karcher Garden
Parts for karcher km 75/40 - Karcher Garden
The discharge pressure on my Karcher electric pressure cleaner varies. When low no cleaning can take place. How can I fix?
Karcher 2 26M Parts List and Diagram 16016020 eReplacementParts com
There are videos on the site that show how to troubleshoot this. The issue is most likely a valve that is sticking open sometimes.
Mar 05, 2018 | Karcher Garden
I have a karcher k2.65m pressure washer which is leaking from inside after removing the outside covers i could not see how to separate the black plastic case to get into the pump etc any ideas ??
A picture might help.
You could always find the part and number here http://www.ereplacementparts.com/karcher-226m-16016020-pressure-washer-parts-c-33388_33389_33977.html Karcher 2 26M 16016020 Pressure Washer Parts
Aug 11, 2015 | Karcher Garden
Karcher Leaking from Back or inside...Help please
Karcher pressure washers are very sensitive to over-winter freezing. The plastic parts break, and you have to replace all of the leaking parts.
You may be missing a locking tab, without seeing the thing apart next to the exploded parts view, it's really hard to tell. Search google for "karcher parts", and put in your model number...
Aug 03, 2015 | Karcher Garden
Where can I find a parts manual on the web for my karcher br 530 bat machine
http://www.sparesgiant.com/cleaning-equipment/floor-care/scrubber-drier/karcher.html
If you have a Karcher then you should always post your machines barcode.
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually modelicon1.png 1.569-874.0 and serial number 00123....
Aug 10, 2013 | Garden
Operating Manuals Karcher 302 presser washer
do you want a "how to use the machine" or "parts diagrams" or "how to repair" ?
"how to use" is the same for all pressure washers...........
i guess you own a KB 302 1.994-923.0 but karcher dont list this "operators manual"
this is for the k 370 :
http://www.sparesgiant.com/media/import/karcher/k370%20op%20man.pdf
The karcher barcode is on a silver sticker and is usually 15 digits long. Example 156987400000123 is actually model 1.569-874.0 and serial number 00123....
Jul 12, 2013 | Garden
Can I get a parts book on the Tornado Karcher CW50? I need to order parts. Thank You
Karcher doesn't publish a parts manual, but there are numerous sites like this one that offer diagrams and allow you to order from a picture.
Oct 12, 2010 | Tornado CW50 - 91450 Bagged Upright Vacuum
I need to replace the high pressure outlet on a k2-26m elecreic
if you contact Karcher they will tell you where your nearest supplier is located. try this link.
http://www.karcher.com/int/contact.htm
Sep 19, 2009 | Karcher K2.26 Electric Power Washer
Karcher power washer electric K3.97 gun has two springs can not find where one goes.
have a look on karcher web site
www.karcher.com
click on europe
then click in international
go to service then spare parts
put in k3.97 and have a look.
hope that will help
damian
Apr 29, 2009 | Karcher K2.26 Electric Power Washer
Can't get the spray gun onto the hose from the washer...no manual
Your posting is incomplete, so I'm not quite sure what we're dealing with here.  I understand the machine and the high-pressure hose are Karcher - right?  Is the gun also a Karcher part?  If all are Karcher parts, they should fit unless the screw threads have been damaged.  If they are not all Karcher parts, they will not fit because Karcher connectors are different from almost all others.
Please post again if this doesn't help, giving as much detail as possible, and I'll see what else I can offer.
Apr 04, 2009 | Karcher PSI Electric Pressure Washer
Garden Logo
Top Karcher Garden Experts
John Trevino
JOHN LAPIER
Joseph Mueller
Joseph Mueller
Are you a Karcher Garden Expert? Answer questions, earn points and help others
