SOURCE: I have a defy top
Error E9 means a problem with your water pressure sensor. Check the sensor by pulling the hose attached to the
bottom part of the tub and blow on it and test the terminals of the
sensor if it will close or open.
Hope helps.
SOURCE: My samsung top loader washing
Hi all of them does it that is the staysoft having a reaction.only thing to do is to full it with water and remove the drian plug at bottom of machine to remove it.hope this helps
SOURCE: manual for samsung top loading washing machine
With your model, I suggest check in this links:- Samsung/samsung_washer_product_list- Samsung/washing_machine__fully_automatic_type
Hope helps.
Thank you all. Will go through all suggestions to see which fault it can be. I somehow think it's an electrical fault. It hums but does not turn in one direction in the wash mode. It turns in the other diection eg, Backwards and forward in wash mode, just turns in one direction. When it gets to go in the other direction, it just hums.... Could it be a faulty capacitor?
Samsung model WA13SP is what is written on back of machine
No. Its direct drive meaning runs on magnetic force and electronic pulse. It sounds like the main board to me
That's not a complete model number. Look on the top back of control panel or under the lid
