SOURCE: Dishwasher won't fill - inlet/outlet light comkes on
check no water in the base either by taking front bottom panel off or tilting back. if water runs out, means you have a leak. could also be inlet valve open circuit
SOURCE: miele novotronic w/m fault light flashing
We had the same problem on a Premier 500 and solved it by tilting the machine forward. Some more water ran out and the lights went off.
SOURCE: Water inlet flashing ,not filling,
Hi Paul,
We currently have a similar problem with our W939. I took the front panel off and found that the Miele service folks had incorrectly routed the ribbon cable linking the fill level sensor with the control panel and severed one of the wires. The machine was reporting a series of errors, one of which was an outlet blockage and the discharge pump was not working.
The relevance to you is that your problem may be a loose or broken wire or corroded terminal.
SA.
SOURCE: Check Inlet
where the water lines attach to the washer at the back un screw them and check the screens on the water valves see if rust or trash is restricting the water flow
SOURCE: Miele W916 front-loading washing machine filling very slowly
Hi
There are two variant of this model one with normal fill hose and triple valve and one with waterproof system and triple valve. If you have change water proof hose (one with grey box on end) then it only leaves the triple valve.if waterproof hose is fitted be sure to order 110volt triple valve
