Question about Janome Sewing Machines
Janome 415 sewing machine loops on backside of material. We've cleaned and oiled the machine. We're using the right size needle, but intermittently loops form on the backside of the material.
  • FrankieMMijares
    FrankieMMijares Feb 26, 2019
    ? i earned $5000 last month by the use of operating on-line most effective for five to eight hours on my pc and this was so clean that i in my opinion could not accept as authentic with earlier than running in this website. if you too want to earn this type of huge coins then come and be a part of us. do this internet-website on line ...........
    g­­­o t­­­o t­­­hi­­­s si­­­te ho­­­me media tech t­­­a­­­b f­­­or m­­­or­­­e d­­­et­­­a­­­i­­­l thank you .
    copy&paste
    HERE?www.101pays.com
    Genius:
  • 1,256 Answers
Are you using old thread? Is the needle threaded correctly, is the thread the same in the bobbin as the top. Are the thread and needle the correct size for the material? Is the stitch length and tension correct for the material? :-)
Posted on Oct 02, 2018
SOURCE:
SOURCE: Janome Memory Craft 9500 Troubleshooting
The solution that I found last night was the thread tension. I have never touched the dial, only had it set on 'auto." When I started playing with it, I realized the top thread should be really easy to pull through the machine and it wasn't. I started turning the dial (to 3 or 4) and the thread slid through the machine perfectly. No more birds nest! I really thought it was bobbin initially because of the horrible sound it was making.
Posted on Jun 05, 2008
SOURCE: CLICK AND GRIND IN 270D BROTHER SEWNG MACHINE
This happened to me and I discovered that my presser foot was stuck up. (LOL) I was using embroidery and the needle was actually brushing against the raised presser foot. So, I turned machine off, removed embroidery part and checked the presser foot switch. It was not moving. Well, I put the machine on regular sewing and just turned the wheel a few times and the presser foot reset. When I went back to embroidery all was fine (and still is). so, check yours.
Posted on Dec 26, 2008
kent581
  • 87 Answers
SOURCE: Viking Lily - free motion quilting - thread loops on underside.
I need more info.
>Where is your presser fooot pressure set(1-9) it should be around 4?
>How fast are you free motioning (faster is better? from 1-10 10 being full speed.
>Is your bobbin threaded correctly (I need to cover the basics.)?
>Never never use a needle smaller than a 90/14 for free motion (I know everyone's an expert...but trust me)
After all this, it's OK to tighten your tension up on top a little when free motioning and getting eyelashes/spider webs on bottom. around 6 should do it though.
Posted on Mar 19, 2009
SOURCE: I just bought a janome mini sewing machine. I
First, in order to get the bobbin thread up, you have to turn the wheel backward, not forward. If you try this, and it is not the problem, keep going.
Next you need to check the needle. There is a screw on the right side of the needle carriage right underneath the underside of the top...unscrew this and the needle should come right out. The flat side of the needle shank should go towards the back of the machine. If it isn't, switch it so that it is and try again.
If this doesn't solve your problem, what has happened is that the gears in the machine have gotten out of alignment. There is an easy fix:
Take off the plate that covers the bobbin chase...there are two screws one on each side. Remove these...you need a stub screwdriver, because regular ones will not fit under there.
Remove the bobbin carriage and the bobbin, making careful note of how they fit back in. Take a picture before disassembling it so you have a reference.
The part that carries the thread around the bobbin is still in the machine. Turn the wheel and you will see it rotate. What has happened is that the needle is not going down in the machine at the right point because someone kept sewing after it jammed and one gear kept going while the other one didn't and now it is out of alignment. These machines have plastic gears and the can slip past each other if you aren't careful not to stop immediately when they jam.
To fix it, you are going to have to do some trial and error. Grab the rotating part of the bobbin chase and hold it firmly. Rotate the wheel forward until you hear it click once. Then rotate the wheel backward again and see if it grabs the top thread. If it doesn't, repeat holding the bobbin chase and turning the wheel forward until it does.
Once you have the gears basically aligned, you will need to reassemble everything. Put the face plate back on and put at least one of the screws in all the way. The face plate holds the bobbin chase in correctly and if you don't fasten it it will not work correctly.
Now try sewing. If it starts to jam, stop immediately, cut the threads and look at the back. If it's a loopy mess, you are going to have to dissamble as before and again grasp the bobbin chase and turn the wheel forward one more click, then reassemble and try again. Eventually, you will find exactly the right alignment and the machine will sew perfectly.
I just had to make this fix on my own machine...I didn't want to take it in for repair because the bench fee alone would cost as much as the machine did!
There are some great video's on YouTube for help with threading the machine...look for StampTV and you should find them. Good luck!
Posted on Apr 21, 2010
  • 35 Answers
SOURCE: pfaff hobby 1132
Many users also had such knocking sound and loops problem. I suggest you to order the following product:
Sewing Machine Repair Guide
It's a professional repair guide written by an expert. Besides PfaFF sewing machine, you can learn how to repair other brands of sewing machine as well. The author claims that you can earn money after you had learned the repair skills!
Good luck.
Posted on Sep 08, 2010
How to thread a janome 415 machine, mines keeps breaking
first, check out the needle, you may need to insert a new one, then the tension and thread for the material you are sewing and make sure that the thread is not too old and that the same thread is in the bobbin and the thread on top. :-)
Sep 29, 2018 | Janome Sewing Machines
Hello dear
have you tried changing the needle?
have you tried adjusting the top thread tension?
it might be the needle and the thread are not compatable,, the needle may be to light for the thread.
if the suggestions don't help, sew on the sewing machine till it makes the loop and then stop the machine and take it to the repair man and let him see the loop and then ask him why it's making the loop.
Jul 25, 2013 | Janome Sewing Machines
HD 3000 loops underneath work
It's most likely not the machine. It's the other things, ie needle, thread, etc. combination. For sewing knit, be sure to use a ball point needle. The needle eye size is important to so the thread is neither too small nor too large for the thread weight.
FWIW, it sounds like bird nesting. --the thread is not seated completely in the tension disk. Remove the top thread from the machine and ALWAYS RAISE the presser foot when rethreading!
Also, check that the tension is appropriate for the project. The two threads should meet in the middle of the fabric. If there is top thread showing on the underside of the fabric, the top tension is too loose. Tighten it until it until the top thread pulls the bobbin thread up into the fabric.
All About Needles SCHMETZ Needles
Dec 04, 2017 | Janome Sewing Machines
Janome 3000 bobbin thread will not catch. It just quit while I was sewing. I've cleaned the bobbin case and anything else I could but when I put the needle down the thread does not circle the b
try changing the needle
rethread the machine top & bobbin
make sure to use every thread guide
make sure the bobbin is not over wound
make sure the bobbin is turned the right way in the bobbin case
make sure the bobbin is not warped or damaged
if you've done all these things then it's also possible that the machine
is out of time & needs to be checked at a repair shop
Sep 01, 2012 | Janome Memory Craft 3000
Janome 6260 not stitching properly. skipping stiches on top and bunching on bottom
New needle, clean under bobbin case and look at this.......Looping thread underneath is a top thread tension issue...
I have written a 5 page illustrated Tutorial on overcoming this problem....HERE
Nov 23, 2011 | Janome 6260QC Computerized Sewing Machine
I am attempting to hem a pair of jeans and when I sew the top thread isn't catching properly and is making big loops between when it DOES catch. I have tried adjusting tension, stitch length, almost...
iam reliable informed that you will need to change the needle by the one who controls this machine in our house for different thickness materials you need different size needles ,or you will get exactly the problems you describe ,iam told to look in the book and see whats suggested for this sort of material ,as some of the smaller machines will not go through tougher type materials and some jean material you will have to do it by hand with a special long needle ,the type of needle i use on my boat for the awnings and sail .
Sep 06, 2010 | Janome 659 Mechanical Sewing Machine
Janome 1600P quilting free motion sewes fine for a bit then top thread starts looping on the back. It is not consistant
Please ensure that you are uing the correct size needle for your that you are using. are you using a straight stitch needle plate. Please let me know what size thread and needle you are using
May 03, 2010 | Sewing Machines
Oiling a Jonome 6600
Remove the plate and bobbin case, beneath it will be a small round hole in the center. Inside the hole is a fluffy piece of absorbant material called the wick. DO NOT REMOVE IT! Place one drop of sewing machine oil on the wick. While you have the machine opened up, you should remove all the dust. I use the small brush that comes with the machine. Replace the bobbin case and make sure that it is clean too. Replace the plate. Lastly add a couple of drops of sewing machine oil to a q-tip and use it to apply oil to the needle bar above the needle clamp.
If your machine continues to squeek then bring it to a professional sewing machine repair technician and pay for the service to have it professionally cleaned and tune up. It is not worth damaging you machine over a few dollars well spent.
Oct 27, 2008 | Janome Memory Craft 5700
Sewing Machines Logo
139 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
