Watches Logo
J
Judith Gardiner Posted on Sep 18, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I set the time on a Rotary Pocket Watch MP00713/01
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Oct 05, 2018
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1813470
Points
13579
Simply pull out the crown, set time and push it back.
2 Related Answers
escapement
Arturs Kalnins
  • 2338 Answers
  • Posted on Dec 17, 2008
SOURCE: I just bought a Mondaine
It seems like your watch has a little short stem and that's why it has only 2 positions. This does not affect battery in any way, nor the timekeeping.
The only downside of this is that you can accidentaly reset alarm time without knowing it as your watch crown is in permanent 1/2 way position.
If you are happy with that - keep your watch.
Anonymous
  • Posted on Mar 13, 2009
SOURCE: how to set the time on relic watches
I had to go to the Sears counter to fix mine. The sales person had to use TWEEZERS to pull the serrated knob up. He had to really work at it. Once it is pulled up you can twist the knob to set the time and then push the knob back down. What a stupid design.
How to set time on my Elgin PQS
  • Setting an Elgin stem-set pocket watch. Pull the stem out of the crown at the 12 o'clock position of an Elgin stem-set pocket watch. Rotate the stem clockwise to move the hands to the correct hour and minute. Depress the stem and wind the crown to keep the watch running.
How do you set the alarm on Rotary watch Ref 10849
To set the Daily Alarm Hour Press the Reset Button (part C) to select "hour" or "minute" setting. Press the Start/Stop Button (part A) to adjust the hours and minutes when flashing. Press the Reset Button (part C) to confirm time change. Press the Real-Time/Mode Button (part D) to return to real-time mode.
1helpful
How do i set the two faces of a rotary relelation watch
What happens when you pull out the button when viewing the white face?
How do I set the time on an old Regina pocket watch. I can wind it and it runs well. The piece to wind the watch does not pull in or out to set the hands.
If you can wind your pocket watch using the crown, but you cannot see any way of setting the watch, you probably have a "lever-set" movement, though it's possible you might also have a "pin-set" movement. Do you see a little button you can push in, either at 1-2:00 or 10-11:00 on the watch case? If you, you have a pin set watch. Push and hold that little button in while you twist the winding crown, and that will let you set the time. End of problem.
Setting the time on a lever-set watch is a bit more complicated and will require taking off the front bezel of your pocket watch--the metal ring that holds the watch crystal in place. Pocket watch cases of this time are usually made in 3 pieces: the bezel, the main case body, and the back. The procedure used to remove your bezel depends on the type of watch case you have.
Take a close look at the front of your pocket watch. Do you see any hinges at the bottom (that is, below 6:00 and where the bezel meets the main case body)? I suspect that you won't, as double-hinged cases are usually associated with an older style of pocket watch, but it's worth checking. If you do see little hinges for the FRONT (it's more likely that the back will be hinged), then look for a little lip on the bezel that's used to pry open the front. Pull on that to open the case.
If you don't see hinges, which is what I expect, your front bezel unscrews. You can try to do this with your bare hands, but it's a lot easier if you have a bit of "gripping" rubber so your hands don't slip so badly. I have a small rectangle of shelf non-slip stuff that works perfectly for this. Turn the bezel counterclockwise. It may resist a little bit at first due to accumulated dirt, but then it should easily screw off.
Once you have the bezel away from the face, look closely at about 2:00 on the watch dial. Just at the edge of the dial, you should see a little lever or button. GENTLY pull this away from the watch face until it stops. Now, when you turn the winding crown, you should be able to set the time. Once the time is set, gently push the lever back to its prior position. Now, you should be able to wind the watch without changing the time.
Be very careful when screwing the bezel back onto the watch body. These parts typically have very fine threads, and it's easy to cross-thread the pieces. Don't force the two pieces together; once the threads catch properly, the front bezel will screw on easily without resistance.
An older style of pocket watch required the use of a little key to set the time from the back of the pocket watch movement. However, these watches were also wound by the same key, so the fact that you're able to wind this watch with a crown suggests to me that your watch doesn't use this system.
May 27, 2011 • Watches
Have a rotary chronograph watch from the 1990's with two set buttons on each side of the face. IE 4 in total. model number G3031. Uses battery UCAR399(both numbers on the back of the case). Asking if...
On the back of the watch there is a circle shape button like. To change the time, push that button like circle with a pointed object until correct time is shown. Check out.Thanks.
2helpful
Cannot set the time on my rotary gb02416/19
loosen the nob by unscrewing it (it may take a little strength to get it going) then once its unscrewed a bit, pull out and set like a regular watch. when your done, push in and re-screw.
May 17, 2010 • Watches
3helpful
How do i alter the time on my rotary watch
You will find user instructions on their web site "rotary.com"
Enter "rotary.com" into your search engine and choose their web site.
Along the top of the page there are a number of labels, put the cursor on "service" and select "rotary watch care", click on this and then scroll down the page until you find "operating instructions".
These instructions cover all there watches and you can choose the one that suits your watch.
2answers
My watch has stopped working
mcdevito75 here, Unless you have a good knowledge of takeing apart, even just the back off your watch / pocket watch it"s best to look for a small watch repair shop in your area, but here is what you can do to possibly start your watch / pocket watch. If your watch / pocket watch hasn"t been wound in some time and that time varies from watch to watch, the oil in the watch can become a bit thick so as to not allow the mechanism to work smoothly, leave the watch / pocket watch in a warm place, window sill in the sunlight wrapped in a paper towel for anywhere between a few minutes to 1/2 hour, after the watch / pocket watch has been warmed up hopefully the oil in the mechanism has liquified enough to allow the movement to start working. You can also give the movement a little boost, after the watch /pocket watch is warm, pull out the stem as if to set the time of day, move the stem and hands, sometimes this action will get the watch ticking again. If this fails, BEST BET specially if this is an expebsive or keepsake watch, look for a small watch repair shop in your area for serviveing. approx. $45.00
Hi i have just recieved a pocket watch but cant work out how to adjust the time.
There should be a button on the top that opens the watch, under this is a dial, you lift the dial not the button, there should be a click and the watch will stop, then swivel the dial to set the time.
I just bought a Mondaine travel alarm pocket watch. Instructions say the crown has 3 positions. 1> Home normal for a quartz watch. 2> Pull out 1/2 way to set alarm. 3> Pull out all way to set time. My...
Dec 12, 2008 • Watches
Top Rotary Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Rotary Watch Expert? Answer questions, earn points and help others
