SOURCE: Frigidaire Electric Slide-in Range - Oven Flash
Richard, sounds like you did all the pretests. You'll need a new display panel. When you work on it, be sure to cut the power.
SOURCE: Frigidaire Electric Range ES200/300
there is sometimes a thermal fuse inside the caseing might have to take the top off if not then you will need a new timer be safe and unplug
SOURCE: Don't know if the oven part of range is gas or electric
The model number can usually be found just inside the door or drawer (on the range itself).
All the Jenn-Air convection ovens I'm familiar with are electric even if the cook top is gas.
SOURCE: my kenmore elite electric slide in range displayed error and F13 and the oven won't turn on
i phoned Sears about error code f13 on a gas range, and was told to unplug the range for 30 minutes. i think she meant 30 seconds - to reprogram the microchip. i unplugged it for 15 minutes or so, then reconnected, and it worked.
