First thing I must add, is that I was using a prerecorded videotape, and was testing it from the beginning of the cassette and the middle of the cassette. I thought maybe the heads were dirty, and so I cleaned them using a cotton swab and rubbing alcohol. I cleaned the head drum with a piece of paper soaked with rubbing alcohol so that I wouldn't get any fibres in the heads. I waited for it to dry and then I put a cleaning cassette inside. To which, it still stopped abruptly five to ten seconds in during playback. I then decided to look at the manual of the camcorder and see the symptom. It says that due to temperature changes that it might cause this symptom. I placed it in a cool room and left it there all day and checked on it, and the camcorder is still doing the same thing as before hand. Then another cause said that it might sense some moisture. I made sure that the camcorder was dry externally and internally, and yet still, same problem. Thats when I decided to take it apart and look inside to see if there was anything odd inside the camcorder causing it to function the way it does. The belt seemed to be working fine, and there was no missing parts. The tracking poles and path alignment was fine, and not loose. Everything simply seemed just fine. So I am unsure as to why my camcorder is operating like this.
SOURCE: Sound dropout
hi, the problem could be because of the problem with the pinch roller ,either it has some wear or the supporting spindle needle has some improper orientation. Is this with a specific tape or all tapes? if it is specific to a tape then it can be because you kept the recorded tape near magnet which causes this rythmic sound drop out. i guess the first one may be mostly happened. all the best sreejith
SOURCE: sony vx2100...blue playback screen
in either case the head condition is bad.. pls inspect the tips on the head whether it is not damaged in the cleaning.inspect the drum hours also..
