Freezers Logo
Victor 29 Louise 28 Posted on Sep 16, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Frigidaire upright freezer is giving me a error code of e8
Chris Walker
Level 3:
Top Expert:
  • Frigidaire Master 1,573 Answers
  • Posted on Mar 29, 2019
Chris Walker
Frigidaire Master
Level 3:
Top Expert:
Answers
1573
Questions
Helped
1244340
Points
21965
5 Related Answers
Anonymous
  • 828 Answers
  • Posted on May 16, 2008
SOURCE: FLASHING E8 (WARNING) ON MY FRIDGE FREEZER
A model number and serial number would help in any diagnosis.
Anonymous
  • 9 Answers
  • Posted on Apr 20, 2009
SOURCE: freezer only cools to 40 degrees
check to see if there is ice built up on the inside back if there is it may have defrost problems or if part of the back has ice it may be low of freon
TheMazz
Kevin
  • 79 Answers
  • Posted on Oct 13, 2009
SOURCE: I have a frigidaire freezer upright model#ffu20f9gw3
Without any additional info, there are a lot of possibilities:
1. Condenser coil (underneath unit) is dirty and clogged.
2. Compressor is failing. (need A/C tech)
3. Metering device is clogged. (need A/C tech)
4. Refrigerant charge is low. (need A/C tech)
5. Door seal is broken (frost will form around door).
6. Defrost heaters are stuck on (replace defrost timer located underneath unit at front).
7. Condenser fan has failed (underneath freezer on back).
8. Evaporator fan (inside fan) has failed (ice will form on cooling coil).
This should get you started...
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Anonymous
  • 152 Answers
  • Posted on Mar 09, 2010
SOURCE: I just set up my Frigidaire upright Freezer, only
Rule of thumb, if you lay a frig/freezer on side let sit upright at new location for 24 hours before plugging it in.
Anonymous
  • 523 Answers
  • Posted on May 06, 2010
SOURCE: 20.3 Cu. Ft. Frost-Free Upright Freezer - White: What could be causing Frigidaire freezer to leak w...
stopped up drain,tear in gasket,not going into defrost soon enough
1helpful
2008 Frigidaire upright freezer giving error code -H9. Can you please help me with this? No notation in manual.
The error code -H9 on a Frigidaire upright freezer typically indicates a communication error between the control board and the display board. To troubleshoot this issue, try unplugging the freezer for a few minutes, then plugging it back in to see if the error code clears. If the error persists, it may be necessary to replace one or both of the boards. Contact a qualified appliance repair technician for further assistance.
Why is my frigidaire upright freezer saying error code e8
I can't answer that but cut all power to the freeser
1helpful
Getting error code 36 hour duration
I appreciate your inquiry, friend!
Based off what you have described your Frigidaire freezer is displaying an error code of 36 hours. Normally it will display that once power has been restored, it is indicating that the freezer has been without power for 36 hours. Hold the "alarm reset" for 3 seconds and that should help clear out the code. I hope this is helpful. -Matt
Thank would guide me about this problem: my freezer frigidaire ffu17f5hwd tells me E8, referred this error
Good Afternoon edgar corro, thanks for your post!
Based off the information you have provided your Frigidaire freezer is displaying an error code "E8". An "E8" error code typically stands for a shorted thermistor this could be a possible miscommunication with the wiring harness, control board, or thermistor. Since it could be anyone of these underlying issues I would suggest contacting a professional technician since they have the appropriate tools to pinpoint the parts needed for repair. Best of luck! -Matt
Power surge on ffu2065fw2 , what wil it do
Hello friend, thanks for your post!
I see that your Frigidaire freezer had a power surge and you're asking what could happen. If your appliance had a power surge it could cause an issue within the board or wiring harnesses. Is your appliance giving any error code or beeping? If so, could you advise what it currently is doing? I look forward to providing you any assistance. -Matt
My frigidaire freezer upright has an error message door ajar
Sounds like the main control board to the unit needed to be reset and with the resetting it has caused a communication error with the door sensor. Contact a service tech to move forward with a repair.
Error code E8
Check wiring to evaporatorsensor. If correct, replace sensor. That will require a professional's attention.
I have an error code on my upright frigidaire freezer "CE". it holds the temp but this error code keeps flashing. how can I get rid of it?
I just unplugged mine and plugged it back in. It works fine now. The problem happened after a quick power outage.
E8 code on display
E8 code on kenmore freezer
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
