Question about Rotel Audio Players & Recorders
Rotel 1098 volume knob turns volume down not up
SOURCE:
techman
  • 3130 Answers
SOURCE: volume knob
In other words the lever that the front knob is attached to is broken or the microswitch is bad or broken.. if your not a tech please take the unit in to a shop as there are no user serviceable parts inside these units. Good Luck
Posted on Aug 03, 2006
marsrover
  • 682 Answers
SOURCE: volume control problem
bring good contact luricat cleaner from near radio shack and apply it over volume and move it forward and backward many times.
Posted on Jul 05, 2008
SOURCE: volume knob
I contacted Jensen and got a real soluton without paying you anything....and it didn't cost me one dime!!!!
Posted on Oct 05, 2008
michigan man
  • 3533 Answers
SOURCE: volume control knob on radio turns volume up at all times
first of all if you live in a cold climate I never turn the radio on until the car warms up if you can remove the knob on the radio spray a light amount of WD 40 and then put the knob back on and turn it back and forth and if you have pop on your hand or water also dry your hands off before touching the radio the lights and the radio will last a lot longer also and also before leaving the car always remember to turn the radio off it will be alot easier on your battery as well
Posted on Jan 05, 2009
gopakumarg43
  • 76036 Answers
SOURCE: rotel rsp 1098
Hello Eric
Just look at its connections. If the input connections have any loose connections at both ends, of the graound connection to both the devices are not proper, this kind of fault [intermittent sound and static noise] can occur.
Reconnect all the connections and check the connection wires. OK.
Posted on Jan 20, 2012
Not playing in stereo
You have blowin a IC in it, Power amps are not suppose to be use for the purpose you were useing it for.You are dam lucky they didn,t go up in smoke.
Oct 16, 2012 | Rotel Audio Players & Recorders
Rotel rsp 1098
Hello Eric
Jan 19, 2012 | Rotel Audio Players & Recorders
Rotel RTC-850 Preamp left channel is silent. After some interconnect swapping, I determined I have a problem with my Rotel preamp. When I play my CD input into the LEFT channel i get the...
Before we throw in the towel, turn it off and exercise every control a lot of times throughout its range, particularly the Tape Selectors. Sometimes oxides will develop on seldom used controls and their 'normally closed' contacts will not pass a signal.
Dec 25, 2010 | Rotel Audio Players & Recorders
How to set digital clock on ix35 Hyundai highlander
Turn the radio on.
Hold down the volume knob for 3 seconds.
The display will come up Volume Setting
Rotate the volume know clockwise until the display switches to time setting.
Push the volume knob.
Rotate the volume knob to select the hour
Push the knob
Rotate the volume knob to select the minute.
Push the knob.
Done.
Nov 30, 2010 | Car Audio & Video
Rotel processor bypass for Audio Research SP10
If I understand you, the 'sound' of the AR preamp is what you're trying to preserve. Presumably you're just running a phono through it as nothing else needs a preamp these days.
The multichannel inputs bypass all of the Rotel's processing except the volume. Use the Front L and R.
Mar 12, 2010 | Audio Players & Recorders
Volume dial doesn't work well anymore - when turning louder, sometimes turns volume lower or just stays at the same volume level
Some manufacturers allow you to set a max volume limit so you don't blow your ears off.  Check the users manual to see how to turn it off.
Also, have tech support install a new potentiometer for you.
Oct 25, 2009 | Rotel RX-975 Receiver
Rotel RA01 amp - volume control
Make sure you connected your record player in the right inputs. Better try it to a line level auxilliary input that is sure to pass the volume control. hope this helps..
Sep 18, 2008 | Rotel Audio Players & Recorders
Rotel RX-800
I have an RX 600 - which has just gone 'phut' - which is how I came today to find this website ! I once had your speaker problem but eventually tracked it down to a bad connection of the speaker cable into the rear of the Receiver. Plastic sheathing and dust was partly in the way. Strip off a bit more plastic to expose fresh bright wire, and remake secure tug-proof connection before you try anything else. Oh, and while you doing it, do the others as well !
Nov 26, 2007 | Rotel Audio Players & Recorders
It has lost partially the mechanical connection between the volume control knob and the volume control pot.
The knob could be "stripped". A drop of a slightly resilient glue should do the trick. Do not use rigid adhesives, as this will prevent future service to this area of your receiver....accordianman
Oct 31, 2007 | Yamaha RX-V630 Receiver
64 people viewed this question
Top Rotel Audio Players & Recorders Experts
 Grubhead
Grubhead
Mike Duncan
Mike Duncan
Are you a Rotel Audio Player and Recorder Expert? Answer questions, earn points and help others
