Question about Hotpoint Ultima WF860 Front Load Washer
Hotpoint Wf860 not spinning on wash cycle. I have a. Hotpoint Wf860 washing machine. I had it apart recently to change the bearings. I had no problems doing this and rebuilt the machine. It no longer spins when it gets to the end of the wash cycle. I can put it on a spin cycle by canceling the wash and putting a spin cycle on. The pump is working as it empties when the wash cycle is cancelled. Can anyone tell me what to look at. Cheers
SOURCE:
SOURCE: Hotpoint ultima wf860
hi, i have the same machine..i have a feeling it does this annually to make you call an engineer. to reset it do this; hold the 'start' button until all lights display, then press 'start' again. hold the 'start' and 'on/off' button together until it reads d-end or d-off. it doesnt always work 1st time so keep trying, good luck x
Posted on Nov 14, 2006
  • 1294 Answers
SOURCE: Does not Spin out the water at the end of a load
If it spins the balance is okay. Check out your filter now. And then the pump (after the spigot prob below) Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
barkencoa
  • 3463 Answers
SOURCE: Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Please rate my advice.
Thanks.
Posted on May 27, 2009
active209
  • 14 Answers
SOURCE: hotpoint aquarius wf340g will wash put wont spin
check solaniod valve on water pump
Posted on Nov 06, 2009
  • 15 Answers
SOURCE: Hotpoint WF860 Cycle does not end
could b presure system blocked up find this on side of filter long plastic *****
Posted on Nov 29, 2009
Very noisy spin wf860
hi if you turn the drum by hand can you feel a slite rumble if you can it will be your drum bearings common problem on a machine that has had alot of use
Oct 30, 2011 | Hotpoint Ultima WF860 Front Load Washer
Nov 29, 2009 | Hotpoint Ultima WF860 Front Load Washer
My hotpoint wf860 child lock button pressed by accident ,now no buttons work want to give fast spin,then wash next load.
Try holding down 'options' & 'select' together the light changes OR 'dry' & 'spin' OR hold down 'end of cycle'. Works for other machines, tell me what did it.
Feb 26, 2009 | Hotpoint Ultima WF860 Front Load Washer
Knocking noise on spin cycle
My machine did the same thing, I found it to be the heater element in the air box had come loose inside the casing and was hitting the sides of the air box. Removed air box from machine and resecured the element now all ok
Apr 10, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WD860 problem
washer wf860 showing f07 error. why
Mar 04, 2008 | Hotpoint Washing Machines
Hotpoint ultima wt960 washing machine noisy on spin
Bearings faulty or another fault this model suffers from is the concrete balance weight retaining bolts shake loose, if it is the bolts tighten up as soo as possible. Regards Advisor
Aug 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
Noisy spin loose drum
drum bearing need need bearing kit and drum support £60 plus labour at similar price. Appliance Doctor
Feb 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
42 people viewed this question
Top Hotpoint Washing Machines Experts
vince
gbob59
James Hehling
James Hehling
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
