SOURCE: dyson 07
when using the hoover it doesn't seem to adjust it's height automatically i have to either put some pressure on the front plate or turn brush off which sometimes seems to work, i have checked filters renewed both the handle hose and the hose under the plate as they both had holes in, but it still hasn't improved
SOURCE: Can I fix height adjusment?
all i no is on the bottom of unit there is 2 smaller wheels that control the height adj. see if that the prob.
SOURCE: Beater bar stalls
Sounds like the belt to the bar isnt turning properly or could be clogged up with dust or need replacing.
Either way youll need to open up the sole plate and check the condition of the belt by the rolling brush bar. Also check the condition of the brush bar to see if it isn't clogged up with general dirt and hair.
SOURCE: Bissell Momentum roller brush doesn't roll w/ pressure
This is going to sound funny, but check the wheels. Sounds like the pin or shaft that holds them is broke. Also check the tension on your belt. If the tension is to loose then the brush will have a hard time spinning.Good luck
SOURCE: Problems with Royal 4000 Classic Bagged Upright Vacuum?
Try this site.
https://www.2instructions.com/search.php?cmarque=ROYAL&modele=4000%20CLASSIC
