Question about Roland Audio Players & Recorders
Have a roland vs2000cd that wont let you select a project. Can I reinstall the system?
3 Suggested Answers
SOURCE:
  • 23 Answers
SOURCE: Roland VS2000CD
Shelly, I have a 2480 but it must be very similar. Import the drum track as a wav file into two of your tracks within the same project. You must make sure the file is a WAV file and nothing else.
Hope it works, on the 2400, I am sure it must since it is a must have.
Mike
Posted on Apr 28, 2008
SOURCE: Roland VS2000Cd Shift Key not working
there's a button near the F buttons that lets you choose between the lcd screen and the vga screen!
I was on the wrong setting.
Simple!
Posted on Aug 15, 2008
I have a roland vs 2480 workstation. i turned it on a while ago and it is not loading a project. can someone help?
Most of those units needed a new cdr drive, which means it's possible that the current material could be lost. Inner Sound is a Roland authorized facility, you can call them.
Nov 18, 2014 | Audio Players & Recorders
My recording studio is stuck on the project load screen
Your VS-2000 is showing symptoms of fragmentation--resulting in the unit freezing or failing to completely load. The only possible solution is formatting the hard drive. Formatting erases all data on the drive.
Note: If you have any files that you need to keep, you may contact our Roland Customer Support department (323-890-3740) to arrange a "Data Recovery" service. Our service technicians can attempt to recover any data that is in your hard drive. Customer Support is available M-F 8:30am-5:00pm Pacific time.
CAUTION!!! Formatting the hard drive erases ALL recordings and data on the drive. This includes any installed plug-ins as well. Be sure to back up all of your project data (recordings) and plug-ins to CD/DVD(s) before formatting the drive.
Unlocking the System:
1. With the VS-2000 powered off, press and hold the TRACK/STATUS button for track 4 and the FX 2 button.
2. With both buttons pressed, turn on the VS-2000's power. Continue holding the two buttons until the display has loaded completely. This can take several minutes.
3. Once the system has loaded completely, release the buttons.
Formatting the Hard Drive:
Note: The format steps below pertain to using the VS-2400's on-board LCD screen. If you're using an external VGA (video monitor), press and hold HOME and press F6 to switch to the on-board LCD.
1. Press SHIFT AND F1/PROJECT.
2. Use the CURSOR buttons to Select "IDE:0".
3. Press PAGE until "FmtDrv" is displayed above F2.
4. Press F2.
5. CURSOR to "Physical Format".
6. Turn the TIME/VALUE dial until "ON" is selected.
7. CURSOR to "Surface Scan".
8. Turn the TIME/VALUE dial until "On" is selected.
9. Press F5 (OK).
10. Press ENTER/YES twice.
Oct 13, 2011 | Roland Vs-2000CD Digital Studio...
Ever since i hooked up the usb ports from my mv8000 to my vista compuiter my roland wont save or it wont load any projects and also it seems that it erased all my songs that i ever worked on, when i start...
I think the most common cause of this with a pc is that windows media player scrambled the data on the hd.. you need to get a harddrive ide ata adapter , open the mv and connect the hard drive directluy to a computer then copy the files.. then reformat the harddrive in the mv then put the files back on .... i had the same problem with a mac but i dont know the cause since i dont have windowns media player.. im interested to know how this turned out.. i thinking of sending my drive to a drive saver company if it doens work out.. i neeeeeeddd my fillleessss.. aaahhhh
Dec 15, 2010 | Roland Mv-8000 Sampling/Record Production...
Lost f/x across all tracks prior to Mastering on Roland 2480cd
Double check that you haven't inadvertently muted or turned down the effect returns. Also make sure they haven't been inserted elsewhere as they wont work as post effects while inserted into a single channel. If you are using some effects, it will cancel the effect card's ability to use its second channel. (ex. mastering suite)
Feb 17, 2010 | Roland Vs2400CD Digital Workstation W/CD...
How to reset my roland spd-s
You can reset Roland SPD-S by using Roland SPD-S utility CD supplied with product.
If you can't locate (or lost) the CD that is included with the SPD-S which contains the factory data, you can download the file here:
http://www.rolandus.com/products/pro...37&ParentId=61
Click the downloads tab and select the "SPD-S Factory Restore Data" (PC or Mac) link.
I think it helps.
If you have any query regarding this issue leae a feedback we were happy to assist you.
Have a Nice Day!
Oct 14, 2009 | Roland Spd-S Sampling Percussion Pad...
Simple!
Aug 15, 2008 | Roland Vs-2000CD Digital Studio...
Roland VS2000CD
Mike
Dec 16, 2007 | Roland Vs-2000CD Digital Studio...
Roland vs 2000cd studio workstation/harddisk recorder.
I have figured out a way to get around this problem without losing your data or sending it to Roland. I have three roland 2480s and have 4 hard drives. Buy another spare drive and when you load up to a different IDE drive shut it down, then put the old drive back into the unit and it will boot from the last known ide. Make sure it is not the same IDE # that was giving you the problem. You will get at your files but you better start to backup and defrag. I will not delete files on my roland unless I am willing to defrag. Buy an extra drive from a third party. You can see a company that sells this stuff on ebay and they are very good. "VS something store."
Aug 10, 2007 | Roland Vs-2000CD Digital Studio...
Top Roland Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
