Polaroid FLM 2601, put imput on rs and menu on TV
SOURCE: power problem - Polaroid FLM 2601
i just repaired mine by replacing the 2 electrolitic caps that had a bulge on the top. they were 1000uf at 35 volts---works again!!!!
SOURCE: polaroid FLM-2601 power supply board
The part number is 6LM00220G0 and is priced at $80.54 at circuit city repair. It is easy to install once you remove the cover from the back of the TV and the housing for the power supply.
SOURCE: how to access the inside of flm-2601
First- unplug it, Second- remove the back( can be tricky), Third- follow the AC cord to the power supply board and your there. Look for any Caps that may be bulged and replace them. Sometimes caps can be bad and look ok. Let ame know how you do>
SOURCE: cancelled dish & hooked up rabbit ears. no local channels
Digital channels require a really strong signal to work well compared to analog. Can you get any analog channels through the tv itself? You will probably need to get a large antenna mounted outside to get these channels to work especially if you are a distance outside the city from where the broadcast is coming from. Sorry for the bad news. It is one of the bad things about the digital transition.
Benjamin
SOURCE: Indoor antenna problem with Magnavox LCD TV Model 15MF605T/17
I have found most of these indoor antennae to be ineffective and a waste of money, however, I do not know anything about this particular antennae. I to have a Dish DTVpal, which I love! It's ugly and probably won't fit in your kitchen, but the best solution is to make your own "bow-tie" antennae, mount it indoors or on the roof and run a cable to the kitchen. Directions can be found on You-Tube. I live in SE Idaho (Pocatello) and can get 13 channels, most without having to adjust the antennae.
