TURN OFF POWER
pull knobs and dials off
open oven door look under console remove toex screws in lower console(control panel)
the front panel glass will drop out
you can know see a metal panel that surface switchs mount too
the screws that hold panel are around the edge the screws that hold cooktop down should be able to be seen
you do not have to remove the cooktop to replace switches
but once the front screws for cooktop are removed the top slides forward and lifts off there will be 1 ground wiire to disconect from cooktop if you do put it back
gl
SOURCE: Surface element doesn't work
When an electric element doesn't work, either it isn't receiving electric power or it's likely that the element or receptacle it plugs into is faulty. Check the other elements. If none work, the circuit breaker has probably tripped. Reset it at the electric panel. If this reoccurs, call an appliance repairperson. If just one burner isn't working, try to pinpoint the source of the problem-- likely a bad element/burner or a problem with its connection receptacle. In some cases it's the switch or the wiring. To replace a bad switch or repair the wiring or replace the receptacle, call an appliance repairperson. A burner that plugs into a receptacle is easy to test. After turning off the range's power at the main electrical panel, just unplug the non-heating burner, plug it into another working receptacle, restore the power to the range, and test it. If the burner works, you know its original receptacle is probably faulty. If it doesn't work in the good receptacle, the burner is bad and should be replaced. Buy a replacement and simply plug it into the receptacle. When you remove the burner, look for burned wires or a charred receptacle. Check the receptacle or terminal block to see if it's cracked, loose or looks burned. If you notice any of the above signs, replace the faulty component, too. If the male burner prongs are corroded, always change the female receptacle it was plugged into. A flip-up burner requires a little more work. After turning off the power, tilt up the burner, unscrew the small screw that holds it, and then slide it out. Disassemble the insulator block by prying off the clips. Then unscrew the wires from the element, replace with a new burner, and reassemble. To test a burner with a multi-meter: First remove the burner from its receptacle, as discussed above. Set the multi-meter to the Rx100 setting (or, for a digital meter, to [omega symbol] or k[omega symbol]. With the red lead connected to the positive jack and the black lead to the negative jack, touch the black probe on one of the heating element's terminals and touch the red probe to the other terminal. The needle should jump from the infinity reading to the right, indicating a properly "closed" circuit. If it doesn't, try the probes on a different part of the metal contacts. Still no reading? Touch the two leads together to make sure the meter is working (the needle should jump). If it works, there is an internal break in the element and it will need to be replaced. When you're finished, turn the power back on.
SOURCE: Help in Removing Frigidaire Smooth Cooktop Burner
What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
SOURCE: Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
SOURCE: Install replacement glass cooktop on thermador electric range
i have thermador range model # REF30RS. my glass broke, i ordered the part, replaced the glass, but i do not remember where all the screwss go. where can i get a diagram?
SOURCE: PLES389DCC Frigidaire Electric Range
I just replaced the top it is very easy if you know which screws to take out unplug the stove
LOTs of hidden screws so remember I only had 4 left overs.
First take the knobs off and the 4 black knobs below the real knob
Unscrew the black thing right under the knob this holds down the STEALESS steel cover for all your screws.
then start taking screws out of the fron the top sides and the screws along the oven door.
The screws near the top releases the glass and frame.
MARK COLOR CODE WITH MARKERS OR TAPE BUT DO IT BECAUSE you wont remember like me.
Wires unplug all of the connections that you see, P11 and P13 is where I had my problem they came off. the board eek
Be careful over lable I just exploded my stove when i put it all back together one wire came off I did not lable it.
239.00 for the board 289 for the glass
IF ANY WIRE COME OFF read the ciruit board Schematic
In still workng on my stove I cant believe it blew up the board.
KDH
