Can't get inside door to ice maker open
SOURCE: Ice maker is not working
if you keep your hands out of the little beam slot on the paddel that is located on the left of the freezer and push it in the beam should shoot across to the reciever on the right and the light should stay on constant, that is if you have the switch on the right side turned on.
if it is turned on and the paddel is depressed and the light is still blinking the you need a beam kit part number 4389102
SOURCE: LG ICE MAKER
Be sure that the fill tube is getting into the ice maker and that the ice maker is not blocked with ice. If everything seems ok, you may have a leaking water valve which causes it to constantly drip water into the ice maker causing the block of ice.
SOURCE: Samsung french door ice maker
Check my solution here. The noisy sound is the swing arm trying to knock out some stuck ice.
http://www.fixya.com/support/t1141317-two_issues
SOURCE: whirlpool refrigerator leaks
the drain hole at the bottom rear is blocked. a pipe cleaner run down it should clear it out.
Water dispensing solenoid is bad. You need to replace the solenoid valve. This typically is independent of the ice maker.
