Possible ???? Oh and battery is charged and good.its a gas golf cart.sorry I didn't mention that above.
SOURCE: 1993 Dodge Dakota repairs. Battery is charged and ...
I have a 93 dodge dakota pick up. When I turn the key I get nothing, The radio and the lights work fine. I had starter checked and the battery changed, It will run if you push it to start but not with the key.
SOURCE: I have a 1984 dodge D150, not charging, battery is
The first thing you need to do is stop wasting your money by replacing parts. Then get a volt-ohm meter and a test light to test the circuits between the battery, the alternator, the ignition switch, the starter relay and the voltage regulator. (a.k.a. Charging System Circuits)
To start, the "B+" or "BATT" terminal on the alternator (large black wire) MUST have a solid, direct connection to the battery. Check for the proper voltage here. Then, the red wire on the alternator at the "F2" terminal should be HOT at all times. If not, you probably still have a bad fuse link that you missed. The "F1" terminal on the alternator (Light Green wire) is known as your "FIELD" wire. It comes from the "IG" terminal at the voltage regulator. It should be hot any time the key is in the ON position. If not, your voltage regulator is not working or your ignition switch is not providing power to the regulator. Finally, The "F" terminal (Red wire) at the regulator should be hot any time the ignition switch is in the ON position. This actually gets it's power from the starter relay, which gets its power from the ignition switch.
Please also review these articles:
What Else Could Be Wrong?
My Car Won't Turn Over
SOURCE: 1990 corvette won't start -
Gm vehicles have had a ton of problems with the antitheft systems. When will turn the starter off when not functioning properly. http://vatspasslockpasskeysecurityhelp.yolasite.com/
SOURCE: I turn the key, hear click click under the dash
Starter ignition switch may have gone bad under the steering coluum
