SOURCE: Fisher & Paykel Model number 402B S.Steel. Bottom frezer top Fridge.
My Fisher & Paykel Model E402B Stainless Steel Fridge/Freezer has a problem. Bottom Freezer is OK but Refrigerator will not work properly, somtimes it will freeze everything now it just warm inside i have checked the the fan and the rubber holding it up has broken also the ice is frozen in the vents can you help i got someone in to fix it but he said it will cost around $600 as there might be more wrong with it, what do you suggest thanks Clare
SOURCE: jeep grand cherokee 2000 3.1 td alarm indicator light situated on dashboard
If this is an after market alarm it could have been turned off.
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
SOURCE: all alarms go off; 1 of 6 alarms has a flashing
Your alarms are interconnected, meaning when one alarm goes off, they all go off. The alarm with the flashing green light is the one that triggered the alarm. If it only went off once, it was probably just fluke thing, and you can reset the alarm memory (flashing green light) by pressing the test button. If it happened more than once, you should try cleaning the alarm. Do this by removing the alarm, and blowing compressed air into the sensor opening (located around the back side perimeter of the alarm). If this fails, replace it.
SOURCE: Power Lamp Flashes Green and Alarm Lamp Flashes 7 TIMES
Count how many times blinks orange lamp and check this error in this forum.
