Question about Kipor Electrical Supplies
Kipor KDE12sta generator under/over voltage LED burning, the engine stops after a few seconds
SOURCE:
CarlGehrke
  • 169 Answers
SOURCE: Problem with a kipor 12 ta generator
I just guessing here but it could mean that the oil pressure is too low.
I'd check the oil level first, then look for the oil pressure switch and temporarily disconnect it.
Regards,
Carl
Posted on Feb 23, 2009
  • 62 Answers
SOURCE: Kipor 3000ti generator, doesn't start, i checked
Drain carb bowl it could have water in the gas
Posted on Apr 07, 2009
  • 6468 Answers
SOURCE: kipor generator starts ok but will not provide electricity to apppliances
first check the circuit breakers if there ok the problem is inside like over heated parts
Posted on Sep 08, 2012
SOURCE: Iam looking to download a manual for a Kipor KDE
Try this link:
http://americanrvcompany.com/assets/images/Kipor/KDE5000ETA%20Operation%20Manual.pdf
Posted on Sep 21, 2015
I need to download kipor kde12sta workshop manual
Here goes. Good luck!
http://generatordeals.co.za/wp-content/uploads/2015/11/KDE12STA-KDE12STA3-Operating-Manual.pdf
Oct 24, 2018 | Computers & Internet
Kipor generator 6500 starting and stoping after few minutes running what could be the problem Diesel model
Im taking it as the engine is cutting out?
Is this a diesel model?
Try, low oil cut off, fuel tank not vented correcly, fuel blockage.
Feb 25, 2018 | Kipor Electrical Supplies
Generator kipor 6700ta, run for a few second and stop, any solution?
hi
you may want to check the filter in the tank if one is fitted check damage fuel line , insure that fuel tank cap breather hole not blocked and injection system
Dec 09, 2017 | Electrical Supplies
hi
this happens when voltage regulator is at fault .
what happens is that the demand out put is ( volts /amps too high ) and engine power is too low causing engine to stop renew or service voltage regulator
Nov 12, 2017 | Kipor Electrical Supplies
My kipor 7000 diesel generator is burning avr. Replaced avr don't last beyond few days. Can someone tell me cause
You need to run these tests in the video to see the state of the alternator. How to test your Electricity Generator AVR Brushes and Alternator on... With this info we can assist you further. :)
The Generator Guru Team
Jan 11, 2017 | Kipor Electrical Supplies
My diesel kipor 5kva generator wont shut by key ,
Caution
the manufacture is recommending a cool down period of about 3 minutes to prevent overheating of the combustion chamber. the following is from the manufacture on shut down procedure.
3.2.8Check Stopping of Generating Set
(1)Disconnect the load from the generating set.
(2)Turn off the air switch of the generating set.
(3)Set the speed lever at RUN position, run the generating set without load for about 3 minutes. Do not stop the engine suddenly, otherwise the temperature will increase abnormally, the nozzle will blocked and the generating set will be damaged.
Press down the stop lever. Concerning the electric starter, turn the key to OFF. Turn the fuel **** lever to S position.
Pull out the recoil starter handle until you feel resistance (at this position, both intake/exhaust valve are closed.) and leave the handle in this position. This prevents the engine from rust.
If the engine keep on running even after the speed lever is placed at the STOP position, either turn the fuel **** to the CLOSE position or loosen the nut of high pressure fuel pipe on the pump side to stop the engine.
Do not stop the engine with the decompression lever.
Do not stop the generating set with load. Stop it after the load removed.
the following link provides the complete maintenance manual for the diesel generator
http://www.rcremers.nl/webshop/handleidingen?download=20:handleiding-aggregaat
Jan 12, 2016 | Kipor Electrical Supplies
My Kipor KDE16STA3 shows p03 error after 15 min runing and shuts down after 3 sec.The voltage drops to 30,40 whta's happening?
[PDF]DIESEL GENERATING SET
www.kipor.com/upload/spec2011053011590766.pdf
3/KDE16STA3/ ..... P-03 Undervoltage: Indicating voltage higher (lower), the generator will self- braking. P-04 Generator ... KDE16STA3 KDE19STA KDE19STA3.
[PDF]2
www.kipor.com/upload/spec2011061109073968.pdf
P-03. Decrease load less than the related load, turn on the breaker. P-04. Replace the fuse of the same type. Check the circuit and inserter. Replace the starting ...
Oct 31, 2015 | Kipor Electrical Supplies
Kipor 6700ta po5 code problems , diesel silent generator
1. Check the voltage of battery whether is 12V or 24V; 2. The voltage of battery is low when the generator is still, then it is necessary to dismantle the battery and charge the battery with charger.
3. If the voltage of battery is low but the generator is running, it indicates that the diesel engine driven charger doesn't work; then it is necessary to stop the engine to check the fan belt.
4. if the fan belt is not loose, please check the charging AC diesel engine driven charger, please refer to Manual for Diesel Engine.
5. If the battery can not store the electricity, please replace the battery for a new one. https://www.dieselgeneratortech.com/generator-sets/discovery-and-elimination-of-faults-of-the-control-system.html
Feb 04, 2014 | Kipor Electrical Supplies
Electrical Supplies Logo
60 people viewed this question
Top Kipor Electrical Supplies Experts
Vernon Taylor
pawnpower
Wayne McNeil
Are you a Kipor Electrical Supply Expert? Answer questions, earn points and help others
