Question about American Standard Home
The back light on my american standard acont800 stays on why ?
3 Suggested Answers
SOURCE:
  • 674 Answers
SOURCE: The heat pump stays on
Remove the cover of the circuit board and controls on the outside unit. Some units have a thermostat that allows you to set the temperature at which it switches to the second stage of heat. Set that for about 34 degrees.
Posted on Jan 03, 2011
  • 185 Answers
SOURCE: I had a new American
INSTALLER SETUP
1. Press SYSTEM.
2. Press and hold these two blank buttons until the
display changes. You will have 5 buttons at the bottom of the stat..... Press the two blank button on either side of the middle blank button till the display changes and then scroll down to 0300 and use the up and down arrows to change from 0 to 1 push Done and you should now have Auto.....if you have other ??? look up a Honeywell Pro 8000 stat it will have the same features...
http://customer.honeywell.com/techlit/pdf/69-0000s/69-1871.pdf
Posted on May 05, 2011
9092301(352627 American Standard Olvera) kitchen faucet swings back to middle and won't stay in position if put to left or right.
Hello, It sounds like a hose may be twisted, or simply may not be secure to countertop/sink may need to be tightened. Careful not to over tighten.
Sep 30, 2013 | American Standard Plumbing
I had a new American Standard ACONT800 termostat installed. Our old thermostat had a settings for "system: heat, aux heat, cool, auto, or off" The new Amer Standard themostat has all but...
INSTALLER SETUP
1. Press SYSTEM.
May 05, 2011 | Heating & Cooling
The heat pump stays on to 20 deg (outdoors) and the burners will not work till the temp is under that leaving the house at a max 65 deg, I beleave the heat pump should true off around 30 -35 deg ? then the...
Jan 02, 2011 | Heating & Cooling
Brake lights stay on and emergency flashers dont blink. are these two seperate issues ?
depends if wiring is europeon standard or that funny american way of the stop lights are the indicators if the later then yes they are related
Nov 05, 2010 | 1998 Isuzu Hombre
I just installed an american standard cadet 3.Home depot rated this toilet as a 10 for flush power. when I flush 1st off the flapper wont stay up on it own long enough to flush,2nd if I hold it open it is...
We have just recently purchased one of the American standard cadet at home depot from a discount flyer and had it for about a day and took it back.
Like you said, Did not notice Any thing like a strong flush.
RECOMENDATION:
Take it back.
Home Depot also sells a Kohler Toilet 1.6 Gallon Flush Install
This is all it said it was. It saves water for sure and has a quick flush.
We liked it so much we purchased two of them because everyone in the house only wanted to using our bathroom.
Hope this tip helps.
r/
David
Feb 24, 2010 | American Standard Cadet 3 Round Toilet...
Need American Standard color name
Called the manufacturer (American Standard). They couldn't identify the number stamped on the sink, but they made a color recommendation based on the apparent date of manufacture. The color name is Daydream, which is a light blue, almost white.
Dec 01, 2009 | American Standard Colony Round Countertop...
Flame wont stay on and have replaced the flame sensor
You have a limit switch that is tripping. I bet it is the flame roll out switch that is very close to the burners. You can bypass this switch to check if it is the one causing the problem by removing the two wires going to it and installing a small jumper wire between them. If the unit starts up, then that's the problem and if not, check all of them. But that's pretty much the only thing it can be. But, you need to double check that the unit is being told to come on and not cutting out intermittently. I doubt it though!
Mar 23, 2009 | American Standard 2083.102 Standard...
Home Logo
69 people viewed this question
Top American Standard Home Experts
US Parts Center
US Parts Center
Donni Steen
Mike
Are you an American Standard Home Expert? Answer questions, earn points and help others
