SOURCE: SAMSUNG AMERICAN STYLE FRIDGE FREEZER MODEL RS21DCNS
Sounds like u need to replace fan motor Check fan motor for continity IF none replace fan motor
SOURCE: Freezer defrost LG american style
Defrost the unit for two days with the doors open...I know you're going to lose your contents. You may have ice on the coils internally. Next make sure you've cleaned the external coils under the unit. Leaving liquids open inside the unit or setting it colder than required will both cause issues like the ones you've got. Also, be sure all air vents inside the unit are unblocked and the door closes tightly all around.
SOURCE: No light in fridge compartment, Not freezing. Light in freezer co
Your door switch is bad. When doors are opened, the fan stops. No cooling. When it closes, fan starts. Bulb is just an indicator of no power to unit...probably burned out contact in switch.
SOURCE: SAMSUNG RS20CCMS AMERICAN STYLE FRIDGE FREEZER
in the freezer section there is a 6 screws. unscrew them and remove the back panel. there will be 2 wires attached to the panels, remember where they go. you will see a metal evaporator which will be filled with ice. this is the problem. use a hairdryer to melt the ice. this is essential as you mustn't puncture the wall of the fridge with any sharp item. before replacing the panel ensure that everything is dry or ice will reform, and also ensure that the fan blades are turning properly or cold air will not be blown into the fridge.
SOURCE: Neff K3990 American style fridge ice maker is not producing ice
The ice maker unit give the command to the water valve to relese water for a short time.
you cna check with volt meter on the water volve that got the pip go to the ice maker unit if it getting 120V for short time when the fingers of the ice maker making full round.
if you get 120v the problem is the valve (the ice maker and the water have difrent water path so its difrent valve used) if you dont get 120v or the fingers of the ice maker not turning then its your ice maker unit need to be replace.
I hope you find this Very Helpful and best regards!
Testimonial: "Many thanks ,will give that a go and come back to you"
