Question about Freezers
Why does the light goes off the igloo chest freezer...Freezer is still working good just wondering why the the light turns off.
  • 388 Answers
Dear sir/mam
kindly make it sure if there not lose connection in the light then if its ok . then check the circuit for the light.
thanks
hope answer the question
Posted on Sep 15, 2018
SOURCE:
bobotfel
  • 241 Answers
SOURCE: kenmore chest freezer power problem
Try to unplug the the unit power supply to reset the error. But if the error persist you have to call for a qualified technician,
Posted on Dec 28, 2007
SOURCE: new chest freezer not getting cold
I am having the same problem. How long did it take?
I bought mine second hand and think it may be broken. I plugged it in 8 hours ago. I can hear it running but it's not cold yet.
Posted on Aug 24, 2008
tborn6
  • 700 Answers
SOURCE: Can I Mount Casters with Screws into Bottom of Chest Freezer?
youyr best bet would be to build a frame that the casters are welded to and there are no holes in the outer shell of the freezer. some L shaped angle would work nicely for this application and then there would be plenty of support for when the freezer is loaded up with product. Be sure that teo of the casters are lockable and two in the swivel freely.
Posted on Dec 27, 2008
SOURCE: maytag upright freezer model MQU1556AEW
I experienced the same problem last week with my freezer. Apparently the change in temperature during defrosting allows the blade locking mechanism to slide on the motor shaft during the spinning operation. The blade pulls itself along the shaft until it comes in contact with the motor mounting bolt. If your freezer just stops getting super cold, but remains cool and you don't hear the fan spinning, remove the inside back panel and check the fan blades for freedom of movement. I almost disposed of the freezer this past week but decided to make one last check of the mechanisms.
Posted on Apr 07, 2009
Bat1956
  • 585 Answers
SOURCE: I have a GE chest freezer and the exterior green
Is this just a "Power-on" light to let you know it's plugged in and has power? This is probably just a "neon" (although the actual gas inside is hydrogen for the green color) bulb and sometimes they will do the flickering thing literally forever. In a way it's a good thing as it makes you look at it. If it really concerns you, or if it is actually a warning that something is going wrong (it should say in the manual, you DO have the manual don't you?) have it fixed under the warranty.
Posted on Jul 07, 2009
I have an igloo frf1050 10.6 cu ft chest freezer. power (red) and running (green) lights are on. compressor hums for 6 to 8 sec. then shuts off. no cooling or freezing. any help?
Compressor may be bad. Also could be the relay that plugs into side of compressor that’s bad. Inexpensive, easy to replace part if it’s the relay.
Sep 21, 2018 | Freezers
Chest freezer not working. Light inside chest freezer comes on but green power light doesn't turn on and freezer makes no sound. What could be the problem.
Could be your thermostat is bad and not calling for the compressor to come on. If you are able see if there is power getting to the compressor. If not then back track to where you are loosing power (thermostat) etc.
Nov 04, 2014 | Magic Chef Chest Freezer MCCF5WBX
Igloo chest freezer 7.2 cubic ft seems running all the time?
It may be on "superfreeze", if there is a yellow light, or it may be set for too low a temperature (try setting the thermostat down to 1 or 2). Check the condenser is clean, and fan working if it has a fan, Check lid is closing properly and the ambient temperature isn't too high.. Lastly, if all else working correctly, suspect short of refrigerant.
Apr 30, 2014 | Igloo Cooler Igloo - 5.2 Cu. Ft. Chest...
My chest freezer shut off (the outside light was
Try to plug somthing that you know it works ,in that outlet ,and if it doesn't work or goes on and off , the problem is in the outlet, but if works without trouble ,the problem could be in the freezer plug , the cord or the cord conections to the freezer.
Sep 13, 2009 | Kenmore Freezer 8.8 cu. ft. Chest Freezer...
The front surface of the chest freezer is
Hi, can you put your hands on front of freezer, and check from 1 to 5 without getting burn? how long can you keep your hands on front of freezer? check from 1 to 20 and let me know, normally there's a condensate line, or part of condenser lines that passes through freezer body , purpose of those condensate line is to prevent your door gasket from freezing , especially during winter. It's normal for front of freezer to be warmed, on hot days it will be a little hotter, you said "very hot" makes me wonder how hot it is, put your hands on front of freezer, use number method and let me know, but it's normal. good luck.
Aug 19, 2009 | Kenmore 5 cu. ft. / 142 liter Chest...
Haier freezer chest not cooling. Green light is
Do not put a towel on your freezer or anything that could prevent a good seal from top of freezer.
jim
Apr 30, 2009 | Zanussi 5.76 cu. ft. / 163 liter Chest...
Temp
jtcarlier
20 Degrees is good
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Aug 24, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
Kenmore chest freezer power problem
Dec 26, 2007 | Kenmore 8.8 cu. ft. / 249 liter Chest...
Freezers Logo
192 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
