I purchased a keyed-alike set of Brinks locks, but need one more. How do I determine if the locks are keyed-alike?
It's highly unlikely you will find more locks with the same key pattern. The ones sold in the big box stores come in case with so many packages keyed alike. Normally 4 packages to the same key, then 4 packages to a different key etc. A locksmith can repin the locks for a small fee if you provide them the locks and the key you want them to match. Some of the stores will do it if you buy the locks from them.
SOURCE: side door lock on 2000 VW Beetle
the dealer gave you a ignition key, instead of valet key.
valet key should open the driver door and ignition. nothing else. if the key can't ope the door. try the trunk. if it open the trunk, the it is a wrong key.
SOURCE: Need instructions for a Brinks security box with keypad and key
Push button in the back, enter 4 to 6 code and push the pound key.
To check combo push star, enter your code, push pound. Safe will beep three times and turn your key.
