2 short beeps when power on
The WSOD, (white screens of deathh(sic))
a very rare thing, and the 2 beeps.
step one, dump out the huge battery and test with only AC power pack. battery this old are bad and short, remove it first. first things first rules.
rule 2, carbon14 dated by me at 2009 made, so the RTC coin cell battery
can be bad (pink bunny spec is 7 year design life)
rule 3 , If BIOS screen are ok, my guess no, WSOD'd.
2 beeps, the silly manual on it does not cover beeps.
beep codes very by model and year and are poorly documented.
i hate lenovo's I buy dell/hp we have real service manuals on our PC USA, by American and win.
or at least ASUS of Twain. (nationalists are cool)
Lenovo's chapter on troubleshooting is useless. for sure WSOD or any hard failures are not covered at all,....
The Infamous SOLDER BALL :ERA:
the WSOD might be the BGA, GPU chip solder failures.
back then they made millions of PC that must pass USA no solder lead rules, no Pb lead. and failed by the millions, 2008/200.
white-screens or worse lines on screen or dead.
twist the screen bezel gently does the screen change.
now do that to the base(GPU side) and does it change. if yes. think bad GPU chip BGA.
BGA = chip with ball grid array pins.
Do more tests?
see left side, see 15pin Dshell VGA port? connect this to a real monitor, VGA get better results? there is hot key for turning on both. page 12 in your manuals states and I quote:
"Press Fn+F3 to shift to other connected display devices."
just key doing that , every 10seconds to see if VGA wakes up.
on many PCs this Press, toggles as 3 or 4 ways below:
internal screen
VGA ext.
both
auto.
that is all I have, more tests are possible and more complex.
one more overheating, clean the vents of lint.
its got a decade of lint inside. so....
1: big battery out (leave out until PC works again)
2: new RTC coin cell, the old one is bad or near.
3: clean the lent out.
4: reseat ram sticks.
5: test with external monitor , VGA port.
6: do the long reset trick>?
a: big battery out,, ac pack unplugged. push power for 30
seconds, release.
b: put only AC power pack fully connected now, and test PC. beep still?
7: last test is complex, we unload the motherboard.
of all modules (any can short, is why)
and test the PC stripped down to near nothing.
see photo of HP stripped to zero.
http://www.pcdied.com/BIOS/blink-w-scr1.JPG
8: remove all ram sticks and test them all 1 by 1, in bamk 0 as the book on your pc shows for RAM population.
warning my PC has 2 top and 2 bottom raM BANKS.
on mine the keyboard off reveals bank 2(RTM is wise)
9:Ask real lenovo forum what 2 beeps mean?
fixya is not Lenovo.
The key to diagnosis, is know things short out, not just open connections like simple ram sticks can do.
(dirt caused on sticks.)
SOURCE: my lenovo n200 does on turn on it beeps and screen remains blank
Hi, you must remove both memories and return to wear them in the socket, it is for it that your equipment not power on correctly
SOURCE: Recently bought a Lenovo Lenovo G550 laptop. Can
If I remember correctly, those speakers were supplied with some Gateway computers equipped with a digital soundcard, and the speakers take only digital input.
Take a look at the input plug and compare it to these:
If yours looks like the mono plug, your speakers will only work with the original digital card. Plug them into your new computer and you'll get nothing out of them.
Hope this helps. Thanks for using Fixya!
SOURCE: how to install xp in lenovo g550, its cant able
fist go bios & give boot from cd RAM save it exit from there insert XP CD it will ask you press any key ,just pess it then it will start coping fails & drivers after that XP will install ok
SOURCE: SOFTWARE OF WEB CAM CAMERA OF LENOVO LAPTOP G550...
HI,
Please click on this link and then click on download.
Hope this will help... Your response is very much appreciated...
SOURCE: lenovo g550 orange flash 3 times
3 orange flashes means flat battery. If you have a faulty charger or charger socket on the laptop then the battery wont charge or power up with just the charger connected.
Look here:Lenovo
